Hello Guest it is November 01, 2026, 11:53:27 AM
Author Topic: Lcam Rev 2.02  (Read 68868 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Lcam Rev 2.02
« Reply #10 on: May 27, 2007, 03:05:52 PM »
Hi, Wes
I'm using LC version as of todays date, That's the only way i've figured out how to now what Ver.it is, When did you up-date LC last ?
The bottom profile looks good, But top is off in your post, Better than Mine.
I drew the A-foil in Turbo-cad 8, Hand drawn with spline feature, It doesn't relate to any foil data sheet.
Hear's a picture of it in Mach3, ready to cut 20 blade's.
Thanks, Chip
Re: Lcam Rev 2.02
« Reply #11 on: May 27, 2007, 03:42:08 PM »
I just updated my lcam and mach3 with the latest betas on the download page  Lcam 2.02 created May 21, Mach3 2.0.073 created May 25.
I was showing these version before but i did a full reinstall just in case.  Fresh downloads and installs.
Same result as i posted.  I've been trying to make mine look like yours but no luck yet.
Art-Brian did ya know that when you install the Mach 3 beta it installs the old version of Lcam?
Have a nice Day
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #12 on: May 27, 2007, 05:25:32 PM »
Hi, Wes
I deleted my LC.xml and wound up with a offset like yours still has a problem on top line.
Thanks for the update on your versions, Helped me figure out the xml was the major problem.
Thanks, Chip
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #13 on: May 27, 2007, 06:00:52 PM »
Hi, Brian
Deleted my Xml and try-ed it again, It's much better except the nose.
Shown with .01 offset's.
In offsets, It looks like LC is using the portion of Dxf that generates the Spline Profile shape, as LC did in earlier normal file in-port.
Thanks, Chip
The DXF for this is on page 1 & below.
« Last Edit: May 28, 2007, 12:17:13 PM by afn09556 »
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #14 on: May 27, 2007, 08:17:12 PM »
Hi, Brian
Hears a copy of the DXF for above Picture, Forgot to tell you it was on page 1.
Thanks, Chip
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #15 on: May 28, 2007, 01:50:47 PM »
Hi, Art & Brian
Having problems with Pocket & Offset's.
Attached below is DXF for box around air-foil, Trying to cut box area and leave Air-Foil.
Needing Some Help Hear.
Thanks, Chip
« Last Edit: May 28, 2007, 01:56:17 PM by afn09556 »
Re: Lcam Rev 2.02
« Reply #16 on: May 28, 2007, 09:01:27 PM »
You will need to use the zigzag to get it to work :(
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #17 on: May 28, 2007, 10:39:52 PM »
Hi, Brian
With  Zigzag it dose the same, Thy also don't finish the Offset's or Pocket's.
In offsets & Pocket's, It looks like LC is Using the portion of Dxf that generates the Spline Profile shape, Not the Spline, As LC did in earlier normal file in-port's.
Look up a few Post's above,
How about posting this Working/Screen Shot, Show Me The Error's I've Made, Many hours spent for such a blow off answer, Just trying to post bug's I Find.
May Be Me, Been there Before, May Be You, Seen That Too. ;D :o ??? ::) and I now it's a Bata-Bata Version
Thanks, Chip
« Last Edit: May 28, 2007, 11:14:17 PM by afn09556 »
Re: Lcam Rev 2.02
« Reply #18 on: May 28, 2007, 11:07:30 PM »
Chip just playing with the airfoil DXF
Wes
Have a nice Day
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #19 on: May 28, 2007, 11:24:42 PM »
Hi, Wes
Thanks, If you'll tighten the Offset up close you will see the errors on the off-setting the airfoil, It's not using the Spline line for off set's.
It looks like LC is Using the portion of Dxf that generates the Spline Profile shape for the offset's, As LC did in earlier normal file in-port's.
Just blowing off some Steam Hear.
Thanks, Chip
« Last Edit: May 28, 2007, 11:34:32 PM by afn09556 »
