Hello Guest it is November 01, 2026, 10:12:58 AM
Author Topic: Lcam Rev 2.02  (Read 68841 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Lcam Rev 2.02
« Reply #30 on: June 01, 2007, 04:48:14 PM »
Hi, Paul
Would you Post your MillTest2 DXF file,
I'd like to look at it.
Thanks, Chip
Offline PaulWC
  •  125 125
Re: Lcam Rev 2.02
« Reply #31 on: June 01, 2007, 05:43:16 PM »
Hi Chip,
It's been posted before under its original file name, but here it is fresh.
Also mentioned in previous post, the dxf offsets correctly in DeskCNC and CamBam on this Dell.
Thanks, Paul, Central OR
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #32 on: June 01, 2007, 06:38:52 PM »
Hi, Paul
I was able to do this with values shown in Pic. below.
What values are you using in your other programs for tool size. ?
Thanks, Chip
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #33 on: June 01, 2007, 06:57:37 PM »
Hi, Paul
There are some Issues though.
Thanks, Chip
Offline PaulWC
  •  125 125
Re: Lcam Rev 2.02
« Reply #34 on: June 01, 2007, 08:14:25 PM »
Hi Chip,
Here's a saved .Lcam project with all the ops I'm after, and a sample of working G-code for the outside chain.
The outside chain is the one I'm having trouible with. The offset for the outside chain is supposed to be a a profile cut that cuts the piece from the rectangular stock.
In my working version, from DeskCNC, I do 0.060" depth conventional mill passes leaving 0.010" stock. Then a climb mill pass at full depth to clean up the edges.
The five circles to the right are drill cycles. The larger circle to the left is done with a pocketing routine.
Your sample shows a pocketing routine for the outside chain.
Thanks for the quick follow-up,
Paul, Central OR
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #35 on: June 01, 2007, 10:09:07 PM »
Hi, Paul
Have a look at this.
I gues while I was working on this 2.05 came out ! ?
Hope this is what your looking to do.
Thanks, Chip
Re: Lcam Rev 2.02
« Reply #36 on: June 01, 2007, 10:18:52 PM »
Check the Rotate and the Move :) I think you will find them a bit better now!
I think that is the Rev that Art put on the web..
www.newfangledsolutions.com
www.machsupport.com
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #37 on: June 01, 2007, 10:28:10 PM »
Hi, Brian
Just started to work with it.
Can .Lcam be added to Attachment Options. ?
The load and post to mach seem to be working now.
Thanks, Chip
Re: Lcam Rev 2.02
« Reply #38 on: June 01, 2007, 10:36:33 PM »
What are you thinking???
www.machsupport.com
Offline Chip
  •  2,055 2,055
Re: Lcam Rev 2.02
« Reply #39 on: June 01, 2007, 10:43:35 PM »
Hi, Brian
Upload Options hear, instead of Ziping it and uploading.
Thank, Chip
