Hello Guest it is November 13, 2026, 06:17:40 PM
Author Topic: Z TOUCH PLATE WAS WORKING??  (Read 9349 times)
« on: January 16, 2016, 01:41:23 PM »
I found that when I put my grounding wire on the bit it sa my
Re: Z TOUCH PLATE WAS WORKING??
« Reply #1 on: January 16, 2016, 01:53:44 PM »
I found that when I put my grounding wire on the router bit it says my toolplate is grounded. If I touch my ground wire to the toolplate it acts normal. But touching the toolplate to the router / bit does nothing. Any help.. only thing I have done different is changed routers...
« Last Edit: January 16, 2016, 02:00:35 PM by Cuemaker »
« Reply #2 on: January 16, 2016, 03:49:54 PM »
Hard to understand by your description, but it sounds like your new router is isolated.
« Reply #3 on: January 17, 2016, 12:33:47 PM »
found bad wire   tks
