Hello Guest it is November 22, 2026, 09:27:50 AM
Author Topic: Version 2803 Problems  (Read 56101 times)
Offline dude1
  •  1,253 1,253
Re: Version 2803 Problems
« Reply #10 on: December 23, 2015, 04:30:21 PM »
marktaft do you have a licences for darwin
« Reply #11 on: December 23, 2015, 05:52:55 PM »
Bummer.... Thought this was going to be a "post your problems with 2803" thread. I have a ton of them!
Offline dude1
  •  1,253 1,253
« Reply #12 on: December 23, 2015, 06:03:52 PM »
just start your own thread
« Reply #13 on: December 24, 2015, 03:45:26 AM »
Thanks for the info Bob,
Think i will need to go back to the darwin thread, did not think it would be so complex , replicating what already works in mach3.
When I finally get mach4 working , will be purchasing a licence for M4.
Happy Christmas
Mark
« Reply #14 on: December 24, 2015, 04:07:57 AM »
I use Mach4 V2803
I use ESS to communicate with my two breakout boards.
When Mach4 ist started and i use other programms i have some trouble.
The keys assigned to Mach4 can't be used in other programms.
best regards
Gerhard
Offline dude1
  •  1,253 1,253
« Reply #15 on: December 24, 2015, 04:27:35 AM »
marktaft if you don't have a licences for darwin output and input do not work only motion is available
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #16 on: December 24, 2015, 10:20:41 AM »
unless you start a thread of your own to list any problems no one can help.
DazTheGas
« Reply #17 on: December 24, 2015, 11:00:07 AM »
I use Mach4 V2803
Known issue.  You have to manually disable the keyboard plug-in - click on the keyboard icon in the system tray (lower right corner of your screen).  When you see a red "X" on the icon, the Mach4 keyboard plugin is disabled and cursor keys will work in other programs.  Then re-enable it when you switch back to Mach4.
Bob
« Reply #18 on: December 24, 2015, 11:01:47 AM »
ALso make sure you aren't hitting the time limits in the unlicensed Mach4 (will halt motion after some amount of time running, I don't remember exactly but like 10 or 15 minutes).
Shameless plug - we offer Mach4Hobby licenses at a discount :-)
Bob
Offline dude1
  •  1,253 1,253
« Reply #19 on: December 24, 2015, 11:36:53 AM »
nothing shameless bob you help here so
