Hello Guest it is November 18, 2026, 12:21:13 PM
Author Topic: Version 2803 Problems  (Read 56030 times)
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Version 2803 Problems
« Reply #40 on: December 31, 2015, 01:13:32 PM »
Actualy I have noticed you keep making a new new profile, can u post the machine ini file this will make it so much quicker to check the settings for you or even better use the package currwnt profile from the help menu and post as a zip file, then we can simply load your profile and test
DazTheGas
« Reply #41 on: January 01, 2016, 01:13:08 PM »
Hey GazTheGas,
here you are...
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #42 on: January 01, 2016, 02:48:58 PM »
As I thought, you need to set your homing in the ess config, yours is empty so the ess dont know what to do.
Heres an example
DazTheGas
« Reply #43 on: January 02, 2016, 11:41:44 AM »
My Version 1.32 does not have this option.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #44 on: January 02, 2016, 01:33:44 PM »
This screen has alway been there in the config section of the plugin.
Step 1 open the plugins.
Step 2 open ESS configure
Step 3 goto homing tab within plugin
DazTheGas
