Hello
Guest
it is
November 22, 2026, 12:21:34 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
mach4 gui failure
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: mach4 gui failure (Read 11500 times)
csherrit
6
mach4 gui failure
on:
March 21, 2015, 06:48:29 AM »
Anyone see this ? win7 32 bit . new install. Gui comes up then "stops working" with this error.
Problem Event Name: APPCRASH
Application Name: wxMach.exe
Application Version: 4.0.1.2270
Application Timestamp: 54ffa633
Fault Module Name: atioglxx.dll
ger21
6,295
Re: mach4 gui failure
Reply #1 on:
March 21, 2015, 07:06:18 AM »
This is probably a video card driver issue.
Try updating your drivers.
csherrit
6
Reply #2 on:
March 21, 2015, 02:35:23 PM »
I don't think that is the issue , I'm running latest driver , system is stable , video plays well . No other applications seem to have issue.
pbarratt
125
Reply #3 on:
March 21, 2015, 03:03:04 PM »
csherrit,
Do a google on atioglxx.dll. You will see that later versions of this caused problems with earlier ATI/AMD cards when running some, not all, software. Answer appears to be to use an older version.
Hope this helps.
Peter
csherrit
6
Reply #4 on:
March 21, 2015, 10:09:13 PM »
Thanks Peter ,
you can get , get catalyst 3.4 version from here :
http://www.oldapps.com/ati.php?old_ati=22?download
extract , don't install , then copy the dll to the mach4 install directory. seems to function , we shall see.
-chaz
Print
Pages:
1
Go Up
« previous
next »
