Hello Guest it is November 22, 2026, 12:21:54 PM
Author Topic: mach4 gui failure  (Read 11502 times)
mach4 gui failure
« on: March 21, 2015, 06:48:29 AM »
Anyone see this ? win7 32 bit . new install. Gui comes up then "stops working" with this error.
  Problem Event Name:   APPCRASH
  Application Name:   wxMach.exe
  Application Version:   4.0.1.2270
  Application Timestamp:   54ffa633
  Fault Module Name:   atioglxx.dll
Re: mach4 gui failure
« Reply #1 on: March 21, 2015, 07:06:18 AM »
This is probably a video card driver issue.
Try updating your drivers.
« Reply #2 on: March 21, 2015, 02:35:23 PM »
I don't think that is the issue , I'm running latest driver , system is stable , video plays well . No other applications seem to have issue.
« Reply #3 on: March 21, 2015, 03:03:04 PM »
csherrit,
Do a google on atioglxx.dll.  You will see that later versions of this caused problems with earlier ATI/AMD cards when running some, not all, software.  Answer appears to be to use an older version.
Hope this helps.
Peter
« Reply #4 on: March 21, 2015, 10:09:13 PM »
Thanks Peter ,
you can get , get catalyst 3.4 version from here :
http://www.oldapps.com/ati.php?old_ati=22?download
extract , don't install , then copy the dll to the mach4 install directory. seems to function , we shall see.
-chaz
