Mach Discussion => Mach4 General Discussion => Topic started by: csherrit on March 21, 2015, 07:48:29 AM
Anyone see this ? win7 32 bit . new install. Gui comes up then "stops working" with this error.
Problem Event Name: APPCRASH
Application Name: wxMach.exe
Application Version: 4.0.1.2270
Application Timestamp: 54ffa633
Fault Module Name: atioglxx.dll
This is probably a video card driver issue.
Try updating your drivers.
I don't think that is the issue , I'm running latest driver , system is stable , video plays well . No other applications seem to have issue.
csherrit,
Do a google on atioglxx.dll. You will see that later versions of this caused problems with earlier ATI/AMD cards when running some, not all, software. Answer appears to be to use an older version.
Hope this helps.
Peter
Thanks Peter ,
you can get , get catalyst 3.4 version from here :
http://www.oldapps.com/ati.php?old_ati=22?download
extract , don't install , then copy the dll to the mach4 install directory. seems to function , we shall see.
-chaz
