Hello Guest it is September 06, 2026, 12:26:48 AM
Author Topic: Vibration At Low Speed! Help please!  (Read 53265 times)
Re: Vibration At Low Speed! Help please!
« Reply #10 on: February 06, 2015, 06:40:07 PM »
Wow... something is drastically wrong.  :o I would bet the Chinese stepper drive is not setup right or failed. People think they are getting a deal buying a $29 chinese stepper then wonder why the machine runs like crap or spend days trying to figure out how to make it work because there isn't instruction. The machine looks like a package deal to me... if that's the case contact to seller.
Seems the Ebay market is flooded with "package machines complete with electronics"... the sellers buy cheap Chinese components then sell the systems for 1000% markup.
« Last Edit: February 06, 2015, 06:43:04 PM by geh7552 »
« Reply #11 on: February 06, 2015, 08:26:45 PM »
Try reducing the axis  Velocity and Acceleration settings  by 50% then test again.
« Reply #12 on: February 06, 2015, 11:14:21 PM »
If I reduce it by 50% the noise and vibration will be more violence!
When I increase it more then will be more smoothly!
« Reply #13 on: February 07, 2015, 02:37:35 AM »
Do you not have any documentation for the drives?
Is it ok at higher speed?
« Reply #14 on: February 07, 2015, 02:43:48 AM »
Yes Hood, at high speed its more smoother.
« Reply #15 on: February 07, 2015, 02:44:33 AM »
« Reply #16 on: February 07, 2015, 02:47:47 AM »
when i press the reset button to move the axis, i hear some a small noise in the motor (before to move them) something like there are some electric pulses in the motor!
« Reply #17 on: February 07, 2015, 03:08:33 AM »
That page doesnt seem to give any info about the dip switches other than to say what they are for. Do you have any other info as it could possibly be you are set for full or half step and at slower speeds it may r un a lot better if you increased the microstepping.
« Reply #19 on: February 07, 2015, 03:20:15 AM »
Try setting the dip switches 5 and 6 to Off On to give you 1/8 microstepping. You will need to adjust your steps per unit in Mach accordingly.
Try setting the decay to FAST  dips 3 and 4 both On.
