Hello Guest it is October 22, 2026, 02:13:34 AM
Author Topic: Csmio/IP-A drives  (Read 91042 times)
Re: Csmio/IP-A drives
« Reply #30 on: March 26, 2015, 05:10:59 AM »
If the encoders are 5v square wave differential then it will not be a problem. If they are single ended then it would be best to get a line driver to make them differential.
« Reply #31 on: March 26, 2015, 05:13:54 AM »
Yes hood it's bidirectional 5v square wave.
Regards ,
Basim
« Reply #32 on: March 26, 2015, 05:17:26 AM »
It should work fine then as it will basically be the same as the original control, motors Tachs to drives for speed feedback and encoders to control (IP-A in this case) for position feedback. :)
« Reply #33 on: March 26, 2015, 05:28:33 AM »
Hood,
is it mean that the settinng the PID could be easier than AC servos without Tachometer??
i want to start my job with the axes!!
please advice,
ghantos
« Reply #34 on: March 26, 2015, 05:40:06 AM »
It should just be the same, the AC servos normally use the encoder for speed feedback although some use resolvers but essentially the tuning of a DC will be the same as an AC as far as the IP-A is concerned.
« Reply #35 on: March 26, 2015, 05:55:05 AM »
Thanks Alot Hood,
Now, i want to start with the axes motions and later to pin out the Inputs And Outputs.....
from your experience, whitch importand switches i need to pin out in Mach3 for begining??
is the Estop is enught at this level.
the problem that in the manual we have good information, but the sequnce and the order of telling the information is not good.
sometimes explaining the I/O then GO to Encoder after that return back to I/O.
its really confusing me.
i will install the mach3 at first then installing the plugin and then wiring then tunning.
what do you thing?
 Ghantos
« Reply #36 on: March 26, 2015, 08:13:46 AM »
Really wiring  will be dependant on your machine but definitely an E-Stop is a must and preferably it should work on the hardware side of things as well, ie drop out contactors or similar so that the drives are powered down. You want to keep the encoders power connected though as it will mean the IP-A and Mach will still know where the axes are even after an E-Stop.
« Reply #37 on: March 26, 2015, 01:21:19 PM »
Hello hood,
I have rade that the firmware version of the csmio/A and the plugin from mach 3 must be the same !!
My newest firmware of the controller is 2.063 and the last version of the plug in on mach3 website is 1.65.
No new versions their !!!
How we can match between !!
Regards
Ghantos
« Reply #38 on: March 26, 2015, 01:31:56 PM »
The plugin comes from CS-Lab and not Mach.
When you download the installer from CS-Lab it updates the firmware and at the same time installs the correct plugin. So if you have the latest firmware you should also already have the correct plugin.
Offline TPS
  •  2,627 2,627
« Reply #39 on: March 26, 2015, 01:34:19 PM »
if you install this:
http://www.cs-lab.eu/en/upload/firmware/setup_CSMIO-IP-A-2.603.zip
you get all you Need.
Thomas
