Hello Guest it is October 22, 2026, 02:14:06 AM
Author Topic: Csmio/IP-A drives  (Read 91044 times)
Re: Csmio/IP-A drives
« Reply #10 on: December 18, 2014, 05:04:44 AM »
Thanks starting to make sense.
Need to order drives and didn't
Want to make a big $ mistake.
Thanks for your help again. I
Will have plenty more questions
I'll sure.
« Reply #11 on: December 18, 2014, 05:07:48 AM »
Best bet is to ask AMC, tell them what motors you have and they will confirm whether they are suitable or not.
« Reply #12 on: March 09, 2015, 09:13:09 AM »
hello hood;
I want to retrofit a machine with CSMIO/P-A.
I have some questions:
how to read a specific Input using the GETOEMLED or GETUserLET??
how I can activate a digital Output??
is it the same like the dspmc ip of vital??
I know that vital already mapped the oemled to match their plugin, so how I can do this in the CSMIO??
if my VFD is +/-10V how I can set it up ??
thank you
Ghantos
Offline TPS
  •  2,627 2,627
« Reply #13 on: March 09, 2015, 09:36:48 AM »
http://www.cs-lab.eu/en/upload/pdf/User_Manual_CSMIOIPA_1.1_EN.pdf
chapter 4.13.3
chapter 4.7.3
chapter 4.13.4
come on Ghantos, the CSMIO manuals are realy good.
« Reply #14 on: March 09, 2015, 11:28:15 AM »
Offline TPS
  •  2,627 2,627
« Reply #15 on: March 09, 2015, 03:03:01 PM »
Hi Hood,
never meet you, but i think we are on the same road.
CSLAB is IMHO one of the most not "experiemental" controlers on this road.
(rest over PM)
Also a good resource on using the I/O
http://www.cs-lab.eu/en/index.php?m=article&show&aid=128&uinfo=Digital_and_analog_IOs__configuration__its_easy#IPA
« Reply #16 on: March 10, 2015, 05:20:56 PM »
Caertainly the most thought out controller I have used, only one thing I wish for is a M76 macro to replace the G76 threading.
« Reply #17 on: March 13, 2015, 02:59:27 PM »
Hi friends,
Regarding the CSMIO-A , what is the function and the usage of the index homing!
What about the pin out mapping for this?
I noted at the user manual that when we use the index homing the pin become "dead" not active?
Could you please explain?
Sorry but this is my first retrofitting project and I have no good experience
Ghantos
« Reply #18 on: March 13, 2015, 05:33:31 PM »
Index homing is a way of very accurately homing. It uses a switch and also the Index pulse of the encoder, it is the way all the industrial machines do homing.
What happens is the axis moves towards your home switch, it triggers the switch and then reverses until the switch is again closed, it then seeks out the Index pulse of the encoder and when that is seen it sets that as home position.
Because it is just using the switch as a trigger to start looking for the Index pulse then it means the switches accuracy does not matter.
To set it up you need to have separate home switch for each axis and you just tell the plugin which input it is connected to and enable the Index Homing in the plugin.
« Reply #19 on: March 14, 2015, 02:14:59 AM »
Thank you hood
But what do you mean by "tell the plug in"
Do you mean in mach3 ports and pins?
I see in the manual that when we activate the index homing the pin become "dead" not active.
Please let me know
Regards
Ghantos
