Hello Guest it is October 23, 2026, 09:51:22 PM
Author Topic: backlash compensation in CAM  (Read 11376 times)
« on: September 29, 2014, 10:35:15 AM »
When I mill parts in Newfangled wizards they machine beautifully.
When I mill using my CAM package (Madcam) my 2d cuts are slightly rough.
I just had a thought. .. I'm using backlash compensation. .. is that not showing in my CAM post?
Re: backlash compensation in CAM
« Reply #1 on: September 29, 2014, 11:15:17 AM »
I am using ethernet smooth stepper
« Reply #2 on: September 29, 2014, 11:31:12 AM »
CAM is not in any way involved in backlash compensation.  That is handled entirely by Mach3.
« Reply #3 on: September 29, 2014, 11:41:03 AM »
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #4 on: September 29, 2014, 02:39:32 PM »
This is most likely a machining strategy issue. Are you using a roughing cut/finishing cut? Are you using the correct feeds/speeds? Are you using the correct type of bit? Are you using a material that can be easily machined?
Happy machining , Jeff Birt
« Reply #5 on: September 29, 2014, 03:05:53 PM »
^^ yes all of the above.  I think madcam uses lines instead of arcs. It cuts awesome in the newfangled wizard... have to check my settings in Rhino and Madcam
