Hello
Guest
it is
October 23, 2026, 10:49:18 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
backlash compensation in CAM
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: backlash compensation in CAM (Read 11378 times)
jonny quest
233
on:
September 29, 2014, 10:35:15 AM »
When I mill parts in Newfangled wizards they machine beautifully.
When I mill using my CAM package (Madcam) my 2d cuts are slightly rough.
I just had a thought. .. I'm using backlash compensation. .. is that not showing in my CAM post?
jonny quest
233
Re: backlash compensation in CAM
Reply #1 on:
September 29, 2014, 11:15:17 AM »
I am using ethernet smooth stepper
HimyKabibble
1,687
Reply #2 on:
September 29, 2014, 11:31:12 AM »
CAM is not in any way involved in backlash compensation. That is handled entirely by Mach3.
jonny quest
233
Reply #3 on:
September 29, 2014, 11:41:03 AM »
Jeff_Birt
1,107
Reply #4 on:
September 29, 2014, 02:39:32 PM »
This is most likely a machining strategy issue. Are you using a roughing cut/finishing cut? Are you using the correct feeds/speeds? Are you using the correct type of bit? Are you using a material that can be easily machined?
Happy machining , Jeff Birt
Check out
www.soigeneris.com
jonny quest
233
Reply #5 on:
September 29, 2014, 03:05:53 PM »
^^ yes all of the above. I think madcam uses lines instead of arcs. It cuts awesome in the newfangled wizard... have to check my settings in Rhino and Madcam
Print
Pages:
1
Go Up
« previous
next »
