Hello
Guest
it is
November 22, 2026, 02:04:05 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Matsuura MV-500 with Yaskawa Drives Retrofit
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Matsuura MV-500 with Yaskawa Drives Retrofit (Read 39999 times)
fly-scale
12
on:
January 31, 2014, 04:09:51 AM »
Hi all,
I want to start to retrofit my Matsuura MV-500
I Want to use Mach3
has anybody experience what is the best way?
Has anybody accomplished an projekt with this components?
The Servopacks are Yaskawa CPCR-MR052 GC
The Feedback Units are Yaskawa TFUE-08ZC7
The Spindle Drive is Yaskawa CPCR-QR-CB8D
All other i/o 's are easy
any helps makes me happy :-)
Logged
Carnoustie, Scotland
Re: Matsuura MV-500 with Yaskawa Drives Retrofit
Reply #1 on:
January 31, 2014, 04:19:09 AM »
Your drives will almost certainly be analogue command, that means you will need an external controller to allow you to use Mach.
I use the CSMIO/IP-A and it works exceptionally well.
The others are DSPMC, Kflop/Kanalog, Galil.
Logged
fly-scale
12
Reply #2 on:
January 31, 2014, 04:42:43 AM »
Thanks a lot for your reply.
CSMIO/IP-A i have seen @ the german Mach3 dealer. it looks great.
nice to hear that it works :-)
Do you use the same Yaskawa 's?
Do you have wiring dokumentation
thanks
Olli
Logged
Reply #3 on:
January 31, 2014, 04:56:16 AM »
No I have Telemecanique Lexium drives on my Chiron.
https://www.youtube.com/watch?v=JS9mh_iMing
What wiring documents are you meaning? for the CSMIO or the drives or the Matsuura?
Logged
fly-scale
12
Reply #4 on:
January 31, 2014, 05:04:15 AM »
from the Yaskawa drives
Logged
Reply #5 on:
January 31, 2014, 05:26:02 AM »
If you do a google search for
CPCR-MR manual
and
CPCR-QR manual
you should get the manuals for them.
Logged
fly-scale
12
Reply #6 on:
January 31, 2014, 05:40:16 AM »
Thas correct, but the Manual you will find is the TSE-C717-12 xx and this does not match with the CPC-MR052GC axis servo drive;-(
Logged
Reply #7 on:
January 31, 2014, 05:42:57 AM »
I may have one at home, will look tonight.
Logged
fly-scale
12
Reply #8 on:
January 31, 2014, 05:47:50 AM »
WOW you are terrific.
thanks a lot !!!
Logged
Reply #9 on:
January 31, 2014, 12:14:40 PM »
Afraid I dont, only one I have here, apart from the one you mentioned, is for CPCR-MR***K
Not sure if it will be any use or not but here is a link.
http://www.yaskawa.com/site/dmcontrol.nsf/(DocID)/TKUR-5EJQ5Z/
$File/TSE-C717-13E.pdf
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
