Hello Guest it is November 13, 2026, 01:00:10 PM
Author Topic: Matsuura MV-500 with Yaskawa Drives Retrofit  (Read 39863 times)
Re: Matsuura MV-500 with Yaskawa Drives Retrofit
« Reply #10 on: January 31, 2014, 12:30:21 PM »
Tanks, but this i have.  There are no Description about The connectors )-:
« Reply #11 on: January 31, 2014, 01:04:43 PM »
Does pg6 not show the connections and what they are for?
« Reply #12 on: February 01, 2014, 04:32:24 AM »
Hello,
page 6 shown i/o, but this is not the same like in pdf i have attached.
the Servo drive has 4 relevant connectors.
1CN
2CN
3CN
5CN
4CN is only internal Servodrive Connection.
in TSE-C717-13E page 6 for example the Tacho is connected to 1CN-6 & 1CN-12
in Yaskawa Doc49 it is on 2CN-1 & 2CN-20
i think, later i have to check the right connector in the machine. i have no other idea to come a step forward.
« Reply #13 on: February 01, 2014, 08:27:21 AM »
Do you have the machines wiring diagrams?
« Reply #14 on: February 03, 2014, 12:03:17 PM »
Hello fly-scale;
I just purchased 2 Matsuura MC-500 mini-master machines.  I plan to retrofit to Mach3 and KFLOP/KAnalog.  This may be a good opportunity to collaborate and save some headaches for both of us.  I am going through the manuals for the Yaskawa drives at this time.  I will keep you up to date on my plans.
« Reply #15 on: February 03, 2014, 12:31:34 PM »
Perfect.
Please take a Look to The spindle and spindle Drive. There i have nothing at this Moment.
Today i was happy to find out The Most for xyz drives and toolchange.
I make a new wiring Diagramm an Post it here.
Do you want clean The wiring Chaos or do you want use this?
Regards
Olli
« Reply #16 on: February 03, 2014, 01:22:46 PM »
Hello,
I will scan and post the wiring diagrams that I have tomorrow (after the snow).  I will also add links for all of the documents and other posts I have found.
John
« Reply #17 on: February 03, 2014, 03:47:21 PM »
What i do last hours.
!!! it is for 230/400V !!!
it is not compleate and i can't give warranty
« Reply #18 on: February 03, 2014, 04:51:03 PM »
Hi Kist,
do you have any idea to connect the XYZ Encoders?
regards
Olli
« Reply #19 on: February 04, 2014, 07:11:46 PM »
Hello,
Yes, I will connect the X,Y and Z encoders to the KFLOP/KAnalog to close the loop.  The encoders have a reference (home) channel as well.  I still need to think about how this will be used or if it is needed.  I will let you know after I get my machines in the lab and start taking them apart.
