Hello Guest it is October 21, 2026, 05:34:51 PM
Author Topic: Mach3 CRP4848 Setup Help Needed!  (Read 8429 times)
« on: January 05, 2014, 08:27:53 PM »
Hi Everyone!
I have assembled a CNC Router Parts CRP4848 over the last few months, and am having problems getting it running.  I can't seem to get the pre-wired Nema 23/G540 electronics to communicate with the Computer/Mach3.  Does anyone else use this system?  I was trying to make it work using Windows 7 32 Bit with a Rosewill PCI card added.  I have since switched to an older computer that uses Windows XP with an on board Parallel Port.  If anyone has any advice, Ports/Pins Configurations, or helpful tips, I would really appreciate it!
Shaun
  •  9,374 9,374
Re: Mach3 CRP4848 Setup Help Needed!
« Reply #1 on: January 06, 2014, 10:24:51 AM »
Check through all the information here to make sure your configuration is correct (including the BIOS settings). http://www.geckodrive.com/geckodrive-step-motor-drives/g540.html
