Hello
Guest
it is
November 22, 2026, 02:17:49 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach4 doing Feed per rev
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Mach4 doing Feed per rev (Read 22955 times)
Brian Barker
3,860
on:
December 30, 2013, 04:17:36 PM »
Here is a short video of me testing the feed per in Mach4. I also have been testing CSS and will try to get a video out of that working...
http://youtu.be/fIXrkznE2IU
It is using the VFD to get the RPM of the spindle over serial modbus so it is not as good as an encoder would be but it seems very good for the tools I used
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
mc
384
Re: Mach4 doing Feed per rev
Reply #1 on:
December 30, 2013, 05:27:15 PM »
You're only posted that to get Hood all excited, didn't you?
Looking good though!
Carnoustie, Scotland
Reply #2 on:
December 30, 2013, 05:48:43 PM »
Nope he skyped the link to me prior to posting
mc
384
Reply #3 on:
December 30, 2013, 05:51:38 PM »
I might of guessed you would of had a preview.
Reply #4 on:
December 30, 2013, 05:59:02 PM »
one of the perks of being a long suffering Mach Lathe user
Brian Barker
3,860
Reply #5 on:
December 30, 2013, 07:42:19 PM »
He is the one that started all this with Mach4.. Hood wanted to have better offsets and Feed per rev that worked like this.. So I should have had the preview LOL
www.machsupport.com
Reply #6 on:
December 31, 2013, 02:13:23 AM »
Video of CSS,
http://www.youtube.com/watch?v=i02DmXtH3XM
Seems to be working well by the looks of the vid
Feed per rev definitely looks to be staying constant as the RPM increases
Maxmekker
5
Reply #7 on:
December 31, 2013, 04:45:50 AM »
All lathe users miss this, hope it can do tool compensation also. Hope this is released soon or a Beta that can be tested.
__________________
Runar Holm, Norway
http://www.maxmekker.com
http://www.facebook.com/MaxMekkersGarasje
Brian Barker
3,860
Reply #8 on:
December 31, 2013, 08:33:32 AM »
Tool Tip comp is on the work bench... I have a plan in place on how to do the tool tip comp. So now I have to turn the crank and make the code
Also this is all in mill at this point so I need to take the time to shift this over to turn and add all the other things I think turn needs (U and W for Inc moves ) Also many of the Gcodes will change.. We can add script calls to shift the machine into Mill mode for you out there with milling on a lathe
www.machsupport.com
BR549
6,965
Reply #9 on:
December 31, 2013, 08:52:37 AM »
HIYA Brian do you have Feed Per Rev working in MILL as well?
Print
Pages:
1
2
Go Up
« previous
next »
