Hello Guest it is November 11, 2026, 07:28:54 PM
Author Topic: Mach4 doing Feed per rev  (Read 22831 times)
Re: Mach4 doing Feed per rev
« Reply #10 on: December 31, 2013, 09:05:39 AM »
Also many of the Gcodes will change.. We can add script calls to shift the machine into Mill mode for you out there with milling on a lathe
This may not be used by many right now but I think it will be soon.  :)
« Reply #11 on: December 31, 2013, 09:47:04 AM »
Yes this is in Mill and in turn.. So you will have CSS and Feed per rev in turn and mill and we don't care where you get the RPM from as long as we can get it ;) This was all scripted in for the demo that I did.
www.newfangledsolutions.com
www.machsupport.com
« Reply #12 on: December 31, 2013, 10:45:04 AM »
Brian,
So what will be the basis of the new Gcodes.......ie: Smid?
If not what?
And while we are it, at a high level of thought, do you have any strong thoughts  on what the lathe screen should look like?
BTW,answers to the above will save ya "5 minutes"   ;)
Rich
« Last Edit: December 31, 2013, 10:48:54 AM by RICH »
« Reply #13 on: December 31, 2013, 12:30:06 PM »
We are going to make it like Fanuc for lathe and mill so it should be like Smid :)
www.machsupport.com
« Reply #14 on: January 01, 2014, 02:41:31 PM »
Brian,
Thanks for the info and I'll need to review the differences in the dialects of code.
