Hello Guest it is October 21, 2026, 12:16:34 PM
Author Topic: Tachus42 Drivers and motors works in Kcam 4 and Not working in Mach3  (Read 38132 times)
Re: Tachus42 Drivers and motors works in Kcam 4 and Not working in Mach3
« Reply #20 on: January 02, 2014, 01:49:25 PM »
Thanx Hood for help and sorry for delay , i got voltmeter later and tested everything many times
2 times tested without any software opened
1 Mach3 idle  (no G-code)
1 mach3 with Gcode  : G0 X200
1 Kcam idle - (without any G-code)
1 kcam with G-code G0 X200
First time test without any kcam or Mach3      (  pin no  -  voltage )
1-9        3.45
10-13   4.70
14         3.45
15         4.70
16         3.45
17         0.05
18-25    0.00
tested again without any software load =  mach3 idle without any gcode = kcam idle without gcode = got same results in three situation :
1          3.49
2-9      0.05
10-13  4.66
14       0.05
15       4.66
16       3.44
17        0.05
18-25  0.00
Results Mach3    with gcode G0 X200
1           3.49
2 >>>> 0.05
3   >>> 3.44
4-9        0.05
10-13   4.66
14         0.05
15         4.66
16         3.44
17         0.05
18-25   0.00
kcam gcode g0 x100
1           3.49
2  >>>  3.44
3   >>> 1.73
4-9     0.05
10-13  4.66
14       0.05
15      4.66
16      3.44
17       0.05
18-25  0.00
i used the cable  : male to male
and tested the output pins :
i hope this results help you to solve this situation :)
« Last Edit: January 02, 2014, 01:55:29 PM by king master »
« Reply #21 on: January 02, 2014, 03:48:43 PM »
I am not sure about the results, can you concentrate on just pins 2 and 3 with both Mach and KCam doing a jog.
From the above it looks like you may have the step and dir pins reversed for Mach.
« Reply #22 on: January 02, 2014, 05:33:09 PM »
Mach :
2 >>>> 0.05
3   >>> 3.44
Kcam
2  >>>  3.44
3   >>> 1.73
« Reply #23 on: January 02, 2014, 05:34:52 PM »
Swap the pins in Mach for the X axis Step and Dir and see if the X works.
« Reply #24 on: January 03, 2014, 06:52:31 AM »
i tested again pin2 in right and left dir
in the right give me 3.45 v   on the left  get  0.05
« Reply #25 on: January 03, 2014, 07:50:03 AM »
Ok so it does seem to be working if the voltages are correct on Pin 2 and the voltage on Pin 3 is also changing from 0.5 to 3.44v.
Could it be you have the Velocity far too high and thus the motor instantly stalls? Does it make any noise when you try to jog?
« Reply #26 on: January 03, 2014, 10:32:00 AM »
it make some thing strange only Hood,
when swap pin 2 , 3
and move right , then quickly move left (with keyboard arrow )  the motor move something like 2 degree ..
then wait some seconds and try again , it move another degree ( just move some right ,, then some left quickly ) or vise
Just need to change the direction very quickly and the motor Jog for 1 sec >>>>
tried and changed everything in motor tuning ........
« Last Edit: January 03, 2014, 10:34:44 AM by king master »
« Reply #27 on: January 03, 2014, 12:04:34 PM »
It sounds like the axis is stalling, try setting a very low acceleration and velocity, also put it into Sherline mode just in case the driver needs a wide pulse.
« Reply #28 on: January 08, 2014, 04:42:03 PM »
tried everything ... no hope to work with Mach3 :( i don't need to work with kcam
