Hello Guest it is November 22, 2026, 08:11:13 AM
Author Topic: Where do I start Bridgeport Interact Series 1  (Read 210097 times)
Re: Where do I start Bridgeport Interact Series 1
« Reply #60 on: November 17, 2013, 02:43:21 PM »
I am actually wondering if it is a differential encoder just without the wires connected. If you had a scope it could easily be tested but sadly you dont :(
Offline mc
  •  384 384
« Reply #61 on: November 17, 2013, 05:21:52 PM »
Going by the 3 additional tinned holes on the PCB, I'd guess it is differential without the wires.
You could check with a multimeter to see if they change voltage when turned to a few random positions, or if your meter has a frequency setting, while spinning it.
The Z would be easy to figure out, but the other two could be a bit more problematic. The trick would be holding the encoder at a point where A and B are in different states (i.e. one high, one low), then matching to their complimentary outputs.
« Reply #62 on: November 18, 2013, 07:44:46 AM »
I'll check the tinned holes later, I noticed yesterday that one of them had no tracks going to it top or bottom, maybe I should just order another encoder? Was thinking about the amt103?
« Reply #63 on: November 18, 2013, 09:56:40 AM »
If that is the capacitive ones, I have heard they are reasonable, however I have never tried any of them. I think they will be single ended so you will need a line driver for it as well.
« Reply #64 on: November 18, 2013, 10:10:39 AM »
I've ordered some AMT103's now and line drives. although I'm mr impatient and I really want to get my machine working tonight. If I connect the old encoders incorrectly, could I damage my controller, (assuming I get 0v and 5v correct)
« Reply #65 on: November 18, 2013, 12:44:48 PM »
No, I dont see how you could.
« Reply #66 on: November 20, 2013, 06:37:04 AM »
I took the safer option, and waited for my new encoders and line drivers to arrive. I purchased an extra one or the spindle too. Hopefully order the threading module when I get some spare cash.
I've been spending all my time reading the wiring diagram and tracing cables in my bridgeport. I do have limit and home switches. Currently all my limit switches are joined in series. Is there any advantage to connect each limit switch to it's own input on the IP-A?
« Reply #67 on: November 20, 2013, 07:24:45 AM »
I just have mine in series however I think if you have separate the the CSMIO will not allow you to jog the wrong way after you reset, could be wrong on that however ::)
Home switches need to be separate for best results though.
« Reply #68 on: November 20, 2013, 07:53:09 AM »
ok thanks for the advice hood.
« Reply #69 on: November 21, 2013, 09:43:20 AM »
I managed to mount the new AMT encoders last night. I modified the old end cap to put a large flat area to mount it on. I didn't realise how tiny these encoders where
