Hello Guest it is November 22, 2026, 08:11:44 AM
Author Topic: Where do I start Bridgeport Interact Series 1  (Read 210102 times)
Re: Where do I start Bridgeport Interact Series 1
« Reply #140 on: December 01, 2013, 06:03:30 PM »
I have changed the x axis motor, with now I made up from 2 spares, mainly had to fit the tacho. The motor now creeps on its own. Could this be because the tacho needs timing? As I just plonked it in?
« Reply #141 on: December 01, 2013, 06:37:25 PM »
Dont know too much about tachos but think it wouldnt matter. Could be your drive needs tuned into the tach voltage if its slightly different from last one. However I think its more likely you just need to redo the offset in the PID tuning page of the CSMIO.
« Reply #142 on: December 05, 2013, 06:53:44 AM »
I've been trying to get the X axis working for a a few days and no luck :( still the axis moved to the right (when connected to the ip-a). I have tried the offset voltage, I find 0.18 moves the axis one way, and 0.19 the other, and it's doesn't let me save 0.185. Anything else I can try?
« Reply #143 on: December 05, 2013, 10:06:51 AM »
Did you get to the bottom of the tripping issue?
« Reply #144 on: December 05, 2013, 10:58:26 AM »
Since changing out one of the motors (this x axis) the machine has not tripped the breaker, although I've not had the axis running for more than a few seconds. As after about a second the mach3 reports a PID fault I guess as it wasn't expecting the axis to move.
However, I only noticed the problem with the motor when I ran my first G code program.
« Reply #145 on: December 05, 2013, 12:21:31 PM »
Could you have the encoder the wrong way? Try inverting the encoder in the CSMIO plugin. See pic
« Last Edit: December 05, 2013, 12:24:08 PM by Hood »
« Reply #146 on: December 13, 2013, 06:30:08 AM »
I've had a few days off this as the wife has had me decorating the kids rooms. I've now managed to stop the motor creeping so I can now start with the tuning. Hopefully I'll get this cracked on the weekend so I can then move on to the VFD for the spindle motor
« Reply #147 on: December 13, 2013, 12:07:27 PM »
What was the cure for the creep?
« Reply #148 on: December 16, 2013, 03:34:57 AM »
The creeping issue I think was mainly my lack of understand on the software interface. I have since learned that the value for offset, may not be the actually value saved. You can type a value in two 3 decimal places, and click apply, and it does save. Simply with playing with this value I resolved my problem.
Yesterday I spent the afternoon cleaning out the sump where all the coolant is kept, There must have been an inch of 20 year old crud in the bottom  Not the nicest of jobs.
Can anyone recommend a coolant fluid?
« Reply #149 on: December 16, 2013, 06:27:03 AM »
Ok, I have never typed a value in that box, I just pressed the button and the control set the offset required.
