Hello Guest it is November 22, 2026, 08:11:30 AM
Author Topic: Where do I start Bridgeport Interact Series 1  (Read 210098 times)
Re: Where do I start Bridgeport Interact Series 1
« Reply #100 on: November 24, 2013, 01:07:16 PM »
Yes, thats correct regarding enables, when you take Mach out of reset the enables go active.
« Reply #101 on: November 24, 2013, 01:11:56 PM »
Yes that pdf is giving you the initial setup steps. If the otors are the same voltage and current and the tachs are the same voltage per thousand RPM then you may not need to tune.
Regarding the DAC, no it should offset for you when you press that, or at least I think it does but you should not be trying to do an auto tune at the same time, just in case thats what you were doing.
« Reply #102 on: November 24, 2013, 01:26:35 PM »
The motors are slightly different voltage, some are 140, 142 and 145. Would is be easier to refit my old motors and buy more of the amt 103 encoders?
« Reply #103 on: November 24, 2013, 01:31:59 PM »
if the voltage, current  and rpm are close it should be ok.
« Reply #104 on: November 24, 2013, 03:47:16 PM »
ok, I've connected the outputs to the relays of each of my axis, I've only enabled the y axis at the moment (one step at a time) ;)
I try the autotuning, but each time the kVff gets to above ~59 - 60 the breaker trips each time,
« Reply #105 on: November 24, 2013, 03:49:24 PM »
You could trying increasing it as long as it is not higher than your drives or motors can handle.
« Reply #106 on: November 24, 2013, 03:51:04 PM »
Just looked at your motor tuning, it is very low for Velocity and acceleration, maybe try increasing them.
« Reply #107 on: November 24, 2013, 04:09:54 PM »
Sorry to be lame hood, which boxes are they? and what values should I start with?? is this still on the PID Tuning (auto tuning) screen?
« Reply #108 on: November 24, 2013, 04:13:58 PM »
In Machs Motor Tuning.
Not sure what the RPM of the motors will be, it wil depend on the voltage you can supply them and what their voltage constant is but I would imagine you will get at least 5000mm/min for Velocity. For Accel you can start off relatively low, maybe 400 and see.
« Reply #109 on: November 24, 2013, 04:30:01 PM »
As always, thanks again for your help.
Just checked the numbers on my motors:
Max rpm is 2500
142volts
4.5nm
Would you still go with the numbers you recommend above?
