Hello Guest it is November 13, 2026, 09:51:19 AM
Author Topic: No signal to Z  (Read 21043 times)
No signal to Z
« on: May 25, 2013, 07:34:17 PM »
Warp9   E189010
smoothstepper driver Ver 17efb, 37, 2.08.36.
the z motor does not lock - the new motor does not lock.
 I reversed the pins no luck
 I swapped the z x cables on the controller z did not jog but, x would jog on z or x. [controller ok]
 I put x on z of the controller and it jogs. [cable ok, controller ok.]
 Mach3 knows and shows jogging. SS diag shows the movement in mach3.
 I'm looking at the SS driver or board ? no signal is getting to z
Whats left ?????
Re: No signal to Z
« Reply #1 on: May 25, 2013, 07:59:02 PM »
Have you checked out your cable/s and connections going to the z motor?
Re: No signal to Z
« Reply #2 on: May 25, 2013, 08:11:20 PM »
Yes Sir
Re: No signal to Z
« Reply #3 on: May 25, 2013, 08:17:16 PM »
I just read all of that.  That does not eliminate your z motor wiring.  In fact it points to it.  Check your z axis cables and connections from the controller to the motor with a meter.  Ohm them out.
Re: No signal to Z
« Reply #4 on: May 25, 2013, 08:25:35 PM »
Ok
Re: No signal to Z
« Reply #5 on: May 26, 2013, 11:48:12 AM »
I checked out ohms on x to see what readings were on a useable cable then I checked z and it has continuity.
Hope you have a good weekend
Re: No signal to Z
« Reply #6 on: May 26, 2013, 12:14:33 PM »
If your cable is good and the connections are good it points to the motor.  I have a hard time believing you got 2 bad motors but that isn't impossible.  If you can swap your wires coming out of the control box and going to the axis motors for the x and z and x works in both positions but z does not work in either position the problem will be between your controller box and the output shaft on the z motor.  Are the motors the same size for the x and z? have you tested through all connectors with the ohm meter?
Re: No signal to Z
« Reply #7 on: May 26, 2013, 12:34:11 PM »
both motors I have will work on x, same size.    attached is my little rig, some guy in china is laughing his ass off.......
Re: No signal to Z
« Reply #8 on: May 26, 2013, 12:46:32 PM »
Yup, your problem will be between the control box and the z output shaft.  I hate to inform you but you are probably running a pirated licenses too.  You will get no more help here if that is the case and you do not rectify it.
Re: No signal to Z
« Reply #9 on: May 26, 2013, 01:23:13 PM »
My licenses are bought and payed for.   From: Greg Cary <support@warp9td.com>
What is between the control box and the z output shaft.
