Hello Guest it is October 24, 2026, 04:22:39 PM
Author Topic: First impressions of CSMIO/IP-A (analogue output version)  (Read 122032 times)
Re: First impressions of CSMIO/IP-A (analogue output version)
« Reply #40 on: August 10, 2013, 03:27:24 PM »
Hello Hood,
I can not send the xml file. It says I already submitted that post. Any ideas how to send it?
Apollo ll
« Reply #41 on: August 10, 2013, 03:38:41 PM »
I will try once more.
Apollo ll
« Reply #42 on: August 10, 2013, 04:12:41 PM »
That (going by size etc) would seem to be the Mach3.exe, it is the xml I need. If the profile you are using is called Mach3Mill then look for a file called that which has a .xml file extension rather than a .exe extension.
Also can you clarify what the ApolloII is please.
« Reply #43 on: August 10, 2013, 09:41:44 PM »
Hello Hood,
Trying again.
« Reply #44 on: August 10, 2013, 09:44:05 PM »
Hood,
The machine I have is a Bridgeport Apollo ll. It is a 3 axis cnc knee mill. 1993 vintage.
Apollo ll
« Reply #45 on: August 11, 2013, 02:17:08 AM »
Ok, that xml attached has the printer port as the controller, if it is definitely the one you are using then you need to go to Function Configs menu then choose Reset Device Select. You then restart Mach and you will be given the option to choose the CSMIO as your controller. If you dont then you do not have the plugin for the CSMIO correctly installed.
« Reply #46 on: August 11, 2013, 02:33:10 PM »
Hood,
Iam sorry but I think I sent the wrong one.
See this one looks better?
Apollo ll
« Reply #47 on: August 11, 2013, 03:15:44 PM »
Ok you dont need to set port and pin numbers in Machs Motor Setup page, all that is needed is you enable the axis. It should not do any harm having numbers there however.
What you have to do is go to Config menu then Config Plugins then Click on the Config at the side of CSMIO/IP-A plugin.
You can then enable the axes and tell it what outputs you are using and also set up your encoder ins etc.
« Reply #48 on: November 12, 2013, 04:39:35 AM »
Mike you can only use the CanBUS for connecting to modules. I have a MPG module and an  extra I/O module up in the operator panel, see pic below of partially done panel.
Sounds like a very interesting machine you had, what make/model was it?
Some very interesting reading here, I'm like a sponge learning things today.
I like the keybaord Hood, do you remember where you purchasaed it from?
« Reply #49 on: November 12, 2013, 08:59:22 AM »
I got that one for free, have purchased the others, I use on Machines, from eBay. There is also a place that sells cheap (relatively speaking ) stainless ones, I was about to buy  one but remembered I still had one sitting in the cupboard :)
http://www.kestronics.com/catalog/keyboards-c-4.html?osCsid=0mgcaj8jfqauoogdll86e92gn2
