Hello Guest it is October 24, 2026, 05:14:58 PM
Author Topic: First impressions of CSMIO/IP-A (analogue output version)  (Read 122053 times)
Re: First impressions of CSMIO/IP-A (analogue output version)
« Reply #10 on: May 01, 2013, 06:52:22 AM »
Can you take a closer up pic of each part as afraid I can not really make out what it is in that pic.
« Reply #11 on: May 01, 2013, 12:15:31 PM »
Hope these give you a better idea.
Apollo ll
« Reply #12 on: May 02, 2013, 01:56:01 AM »
Ok the wiring for jog and motion still dont really help much but the clamp looks like it may be a prox switch. You would really need to find out the part number of that prox to see what voltages it can handle.
The pic of the other two controls however help a bit. The Jog +- looks like it is a potentiometer and the Axis motion looks like it is a MPG. The pot should be easy enough as you would connect that to an analogue input, ie one side to 10v, other to 0v (Gnd) and the middle to  an analogue input.
The MPG, you would really need to see if you could find a part number on it to make sure it is indeed a MPG that is putting out ttl signals. If it is then really you need the MPG module for the CSMIO, the other opyion would be to convert the 5v signals to 24v and put into the CSMIO itself but I am not sure how well that would work, so try and find out what all components are first by looking at their part numbers or any other info they have on them directly.
« Reply #13 on: May 04, 2013, 11:57:26 AM »
Hello Hood,
As far as the axis motion, and the jog switch Im going to order the MPG Module and pendant from CS Labs.
You were right it is a proximity switch. Part number EGT12x02AP024-SEM4. It looks like it will handle 30volts, and 250ma. Im not sure how to hook it into the CSMIO though?
Any ideas?
Thanks for all your help!
Apollo ll
« Reply #14 on: May 04, 2013, 01:07:22 PM »
Do you have a link to the data sheet for the prox?
« Reply #15 on: May 04, 2013, 02:00:01 PM »
The web site I found it on is, www.datasheets.globalspec.com
Part # EGT 12x02AP024-SEM4
Apollo ll
« Reply #16 on: May 05, 2013, 02:23:48 AM »
Can you attach the data sheet as I am not really finding much with that exact part number.
« Reply #18 on: May 05, 2013, 12:33:08 PM »
Afraid I would have to sign up to download that data sheet. It took me a long time to get rid of the constant bombardment of emails from Globalspec before, so not going to do it again.
If you have downloaded, please attach here using the additional options button.
« Reply #19 on: May 05, 2013, 02:25:48 PM »
here is the pdf
