Hello Guest it is November 22, 2026, 09:39:02 AM
Author Topic: cannot run Mach from mid point  (Read 9238 times)
« on: March 30, 2013, 11:49:22 AM »
Why is it that if try to start Mach 3 from "run from here", the machine goes way off its coordinates?  I've done it  hundreds of times with different code and it always worked fine.  This is a new project, with new code, and it runs fine if I start from the beginning.  If, on the other hand, I bring the machine home, and then set a point in the code other than the beginning, the machine forgets its coordinates.  Why am I missing?
tony
Re: cannot run Mach from mid point
« Reply #1 on: March 30, 2013, 01:31:53 PM »
Attach your xml and your code and say which line you are wanting to start from and I will see if I can find a problem.
