Hello
Guest
it is
October 25, 2026, 07:02:52 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Re: Newbie with KL-4030 1st time testing problems
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: Re: Newbie with KL-4030 1st time testing problems (Read 63374 times)
Pysiek
36
Re: Re: Newbie with KL-4030 1st time testing problems
Reply #40 on:
March 29, 2013, 04:28:41 PM »
The only weird thing it is right now that no matter if I press the master switch or leave it unpressed everything works fine. I thought if I release the master switch then nothing will work
Chaoticone
5,624
Precision Chaos
Reply #41 on:
March 29, 2013, 04:43:22 PM »
Do you have to set up the master switch as an estop input?
If you could see the things I have in my head, you would be laughing too.
Pysiek
36
Reply #42 on:
March 29, 2013, 04:50:32 PM »
No. Estop is set up on different input.
Overloaded
4,923
Reply #43 on:
March 29, 2013, 05:06:31 PM »
The C10 I am using came with a very small single strand wire installed as a jumper between the EN and GND terminals. If this connection is open, all outputs should be disabled.
Russ
Pysiek
36
Reply #44 on:
March 29, 2013, 05:22:01 PM »
That's where I connect the master switch as per wiring diagram. But when I disconnect it it still moving the motors
Overloaded
4,923
Reply #45 on:
March 29, 2013, 05:48:01 PM »
Remove everything from those 2 terminals and try it.
There could be something goofy with your switch or wiring.
Russ
Overloaded
4,923
Reply #46 on:
March 29, 2013, 05:49:34 PM »
...really, just remove everything from the EN terminal.
There might be something else connected to and relying on the GND terminal.
Pysiek
36
Reply #47 on:
April 01, 2013, 06:16:55 AM »
I will try that later after work.
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
