Hello
Guest
it is
October 30, 2026, 05:24:59 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
LazyTurn
LT gcode diameter larger than needed
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: LT gcode diameter larger than needed (Read 79389 times)
moskit
6
on:
February 01, 2013, 02:39:31 PM »
Guys, any one had something like this?? i post gcode with 26mm but the gcode ends 26.400
Z-36.6834 X25.6382
Z-37.7449 X25.8082
Z-37.7696 X25.8120
Z-38.8344 X25.9602
Z-38.8591 X25.9635
Z-39.9515 X26.0926
Z-41.0464 X26.1991
Z-42.1431 X26.2832
Z-43.2414 X26.3446
Z-44.3407 X26.3835
Z-45.4406 X26.3998
Z-80.0000 X26.4000
Z-80.0000 X26.4000
Z-80.0000 X26.4000
Thanks for any advice
Last Edit: February 01, 2013, 02:41:08 PM by moskit
Re: LT gcode diameter larger than needed
Reply #1 on:
February 01, 2013, 03:49:21 PM »
Post the dxf file. Provide a pic of the tool definitions that you are using.
Machtank
69
Reply #2 on:
April 28, 2013, 12:14:15 AM »
Yes ! I get that too.
It seems to be mainly influenced by the Tool radius specified. (finish cut settings also have a slight effect)
mohamedhelmi
14
Reply #3 on:
November 15, 2013, 12:09:38 AM »
I have same problem.
what that means ? and what is the solution ?
Reply #4 on:
November 15, 2013, 03:56:31 AM »
mohamedhelmi
14
Reply #5 on:
November 15, 2013, 04:00:56 PM »
Dear Rich,
please check attachment, and for info this broblem happen for all tests that I do.
when transferring from AUTOCAD to LT all ok. but when posting from LT to Mach 3 the Diameter of the ROUGH path looks clearly more bigger than the FINE path.
Reply #6 on:
November 15, 2013, 08:12:53 PM »
Can you save and then post your drawing as a version 12 dxf?
I can't open your drawing.
mohamedhelmi
14
Reply #7 on:
November 16, 2013, 01:00:05 AM »
dear Rich,
I dont find extention .12DXF
I have DXF (autocad 2010,2007, 2004, 2000, 14 )
does .DXF means (DXF autocad 12) ?
Reply #8 on:
November 16, 2013, 04:45:51 AM »
I use Autocad 2007. It will not read newer versions.
Save the file as shown in the pic.
mohamedhelmi
14
Reply #9 on:
November 16, 2013, 05:58:27 AM »
OK Rick,
I'll do it asap (because I'm at work right now)
thanks
Print
Pages:
1
2
Go Up
« previous
next »
