Hello Guest it is November 22, 2026, 08:11:35 AM
Author Topic: Upgrade of licenced version  (Read 12869 times)
« on: January 06, 2013, 06:18:48 PM »
Hi guys,
Apparently I need to do an upgrade to a later version so I can use the latest set of  M10/M11 codes for switching a laser.
 I have a fully licensed version on disk,  R3.043.022 .  Where is the UPGRADE for licenced versions located . ( I can only find the DEMO download.Sorry for such a dumb question.  ???
Thanks in advance.
Re: Upgrade of licenced version
« Reply #1 on: January 06, 2013, 06:23:12 PM »
Download  a demo version and install over the top of the old version and just put the license in the installed Mach folder.
« Reply #2 on: January 06, 2013, 06:36:57 PM »
OH I FEEL SOOO DUMB.
You say to just put the license in the installed Mach folder.( Where is the license ( On the disc I purchased?)
SORRY, U must be in histerics by now.  ( Or crying)
« Reply #3 on: January 06, 2013, 06:47:15 PM »
Sorry, I could use a good laugh but unfortunately you will need to do better than your question. ;)
Open Mach, click the Help tab, select About Mach3Control and the flyout should show your name and version.
Is that what you are seeing?
« Reply #4 on: January 06, 2013, 07:24:52 PM »
Yes it shows my name, but it still shows the old version. I downloaded the new version but installed it to a different folder for now ( C:/ Mach33/mach3)
( I am scared it will wipe all my current settings if i install it into my Mach3 folder ( IT TOOK ME WEEKS TO GET ALL MY SETTINGS CORRECT )  ;D
« Reply #5 on: January 06, 2013, 07:39:49 PM »
OK I grew some cohunas and put the latest ver download file into the Mach3 folder. All is now well and I have the latest release. Thanks for all your help. I have deleted the Mach33 folder as it was confusing me.... and as u can tell by now .....that's VERY easy to do!!  :-[ ;D
« Reply #6 on: January 07, 2013, 05:16:11 AM »
Happy you got it working.
« Reply #7 on: January 07, 2013, 11:33:34 AM »
Just to add since you mentioned you'd hate to lose all your settings, I would personally just make a copy the whole Mach 3 folder and paste it somewhere safe, just in case you mess it up somehow.  ;)
