Hello Guest it is September 06, 2026, 04:35:49 AM
Author Topic: Mach3 and Tapmatic Tapping Head  (Read 120087 times)
Re: Mach3 and Tapmatic Tapping Head
« Reply #30 on: October 29, 2012, 05:55:11 PM »
out of 4 taps i have 1 left lol.
m3 tap didnt work to bad, but trying different things i broke two.
m2 tap broke within about a second
was using g95
« Reply #31 on: October 29, 2012, 05:55:37 PM »
oh and adding spindle feedback is possible but a right pain in the arse
« Reply #32 on: October 29, 2012, 06:09:28 PM »
Just looked at your denford data question and looks like you could add a disc to the motor shaft. All it would then need is an opto going into your parallel port. Even if the motor is not direct drive that wouldnt matter as you can tell Mach to divide the index signal by whatever the gearing is.
« Reply #33 on: October 29, 2012, 06:23:07 PM »
in the long run yes i could, but it would be nice to get the tapping head up and running now.
need to order some more taps.
only got one m2 tap left
« Reply #34 on: October 29, 2012, 06:27:16 PM »
MAKE sure you are optimum on the hole size for tapping and are using the correct H# for the tap application.  SUper tight fit toleranace on threads do not always make the best thread, usually all you get it is broken taps in an expensive part to fix.
« Reply #35 on: October 29, 2012, 06:33:09 PM »
im using a 1.6mm hole for an m2 thread and 2.5mm hole for m3 thread
« Reply #36 on: October 29, 2012, 06:35:30 PM »
this is what someone has recommended
http://www.cncdoctor.co.uk/index-pulse_62.html
« Reply #37 on: October 29, 2012, 06:42:36 PM »
« Reply #38 on: October 30, 2012, 07:20:34 AM »
« Reply #39 on: October 30, 2012, 09:47:25 AM »
You could use a manual tach but it would mean to be sure you would have to measure each time you were about to tap to make sure the spindle was turning at the speed your code was telling it to. I would say it would be much simpler connecting up a spindle sensor of some sort, that way you would have a constant true speed reading in Mach and G95 moves would be based on that RPM rather than what you have coded.
