Hello
Guest
it is
November 13, 2026, 12:23:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Plasma -Easy question but got me stumped
« previous
next »
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: Plasma -Easy question but got me stumped (Read 64854 times)
TomTom
49
on:
October 09, 2012, 05:40:43 PM »
Mach 3- Sheet cam - plasma.
<<Cut start is above rapid clearance plane.......... >>
What did I do wrong?? TYIA.
BR549
6,965
Re: Plasma -Easy question but got me stumped
Reply #1 on:
October 09, 2012, 05:58:26 PM »
You have the position for the start of the cut ABOVE what you have for the rapid clearance position. Look in the tools section for the cut height and check under job options for the rapid height setting.
Last Edit: October 09, 2012, 06:01:19 PM by BR549
TomTom
49
Reply #2 on:
October 09, 2012, 11:34:09 PM »
I am new, so very sorry to be so dumb. I redrew it and opened in sheet cam , ran the post processor and get the same error as before, but last time it gave me 6 of the same error, now it is down to 1. but same error as before.
TomTom
49
Reply #3 on:
October 09, 2012, 11:47:00 PM »
In sheet cam can you insert the kerfs like you do in autocad?
TomTom
49
Reply #4 on:
October 10, 2012, 12:56:50 AM »
GOT IT. THANKS for the help.
BR549
6,965
Reply #5 on:
October 10, 2012, 09:27:49 AM »
Scam will compensate for the kerf width for you. Just draw to size and specify in your tool setup what the kerf width really is . Then Scam will offset the code to compensate.
(;-)TP
TomTom
49
Reply #6 on:
October 10, 2012, 09:16:25 PM »
LOL. Thought I had it......It is making all the cuts twice the size I drew them in Draftsight. I there a place in Mach3 to adjust sizes?
Thanks Again. Tom
TomTom
49
Reply #7 on:
October 10, 2012, 09:19:26 PM »
I.E. I am cutting a 3.5 inch disc with 4---- 3/4 inch holes. I am getting a 7 inch disc with 4------1 1/2 inch holes.
woodspinner
100
Reply #8 on:
October 10, 2012, 09:57:41 PM »
well, you can adjust scaling, to the right of each dro, where it says "1" change it to ".5" Probably much better to adjust sizes in cad/cam .
John
BR549
6,965
Reply #9 on:
October 11, 2012, 09:36:22 AM »
BEST to get it correct in the CAD side. OR are you scaling it bringing it into Scam ?
Print
Pages:
1
2
3
4
5
Go Up
« previous
next »
