Hello Guest it is November 11, 2026, 04:33:43 AM
Author Topic: Plasma -Easy question but got me stumped  (Read 64648 times)
Re: Plasma -Easy question but got me stumped
« Reply #30 on: October 13, 2012, 10:44:44 PM »
X -Y-A-
Steps per - 1630
Velocity - 499.98
ACC - 50
Gs - .12950952
Step pulse - 5
Dir pulse - 3
Z axis is up/down and settings are lower.
1630
90
60
155411424
5
3
« Last Edit: October 13, 2012, 10:58:39 PM by TomTom »
« Reply #31 on: October 13, 2012, 11:21:33 PM »
 ;D How long did it take for you to get that sharp? worked like a champ. ;D
« Reply #32 on: October 14, 2012, 12:52:41 AM »
Don't forget to check the Z axis as well(;-)
« Reply #33 on: October 14, 2012, 01:15:07 AM »
Speaking of Z axis........It was slamming down to the plate, now it is stopping before it gets all the way down. Specs on the Z are :
1630
90
60
155411424
5
3
 I feel like I am getting close to getting a part cut. LOL.
« Reply #34 on: October 14, 2012, 01:56:27 AM »
And next I get to play with velocity. It makes a whinning noise while makeing a cut. :)
« Reply #35 on: October 14, 2012, 09:38:28 AM »
Bring the velocity down to about 200 accel about 25 and see what happens.
« Reply #36 on: October 14, 2012, 01:57:28 PM »
Need to get the Z to stop hitting the metal before it fires and drags on the sheet. Any ideas? Thanks.
« Reply #37 on: October 14, 2012, 03:54:12 PM »
DId you check to see IF the Z moves the correct distance?
« Reply #38 on: October 14, 2012, 04:10:17 PM »
Well now it is different (guess I done something else wrong, but it doesn't hit the sheet anymore. It cycles from the top of travel and stops  1 1/4  inches above the sheet. way too high but better  than it dragging on the metal. BTW.     Z  travels about one inch.
 I wish i could control the height manually!!
« Reply #39 on: October 14, 2012, 05:41:02 PM »
YO have not answered the question(;-) Does the Z move the distance programmed ?  UNtill you have ALL the axis's moving the correct distance it won't work correctly.
DO you have a floating Z that has a switch to find the top of the material?
