Hello Guest it is November 13, 2026, 10:00:05 AM
Author Topic: Multiple joy axis togheter  (Read 29205 times)
« on: January 22, 2007, 01:13:51 PM »
Hi all,
I bought a new game pad which has 2 analog joysticks, so 4 axis in total. My intention is use at least 2 axis or more to control my machine, even together to do diagonals. What I want to know is what I have to do to achieve this, in terms of plugins to install and how to configure it.
Before you say it, I know the info are already here, but no matter how hard I tried, it's impossible for me to gather all the pieces togheter, so a recap would be very nice. Let's say starting from a basic mach3 install up.
Thanks in advance to all!
Re: Multiple joy axis togheter
« Reply #1 on: January 22, 2007, 10:38:48 PM »
At this point the joystick plugin will only run a two axis :(... I wish I had the time to make it work  with more!
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: January 23, 2007, 10:21:32 AM »
Wasn't there another plugin which was able to do so? I think it was called keygrabber. Isn't that one supposed to work with more than 2 axis?
« Reply #3 on: January 23, 2007, 01:20:41 PM »
You can do this in KeyGrabber. KeyGrabber is not a plugin.
http://www.machsupport.com/forum/index.php?topic=1391.0
« Reply #4 on: January 24, 2007, 10:50:43 AM »
I tried keygrabber, and while it seems to work ok, I can't find a way to use 2 axis simultaneously. Is this even possible?
« Reply #5 on: January 24, 2007, 11:30:15 AM »
Yes Francopuk, it sure is. I will post some screen shots in a few to help.
« Reply #6 on: January 24, 2007, 11:57:17 AM »
Here are a couple of screen shots to help.
I have sent you a PM Francopuk.
Offline JB
  •  15 15
« Reply #7 on: January 24, 2007, 10:56:49 PM »
Chaoticone,
  Are you using a serial or USB joysticK?  I found a Saitek USB for dirt cheap and would like to use it (yes I've already spent the $2). Keygrabber is a bit past where I'm at right now, but if USB does work, I'll jump on that aspect next. I appreciate the the feedback (sorry id Iv'e mispelled, the keyboard seems to be fighting me tonight).
THX,
John B
« Reply #8 on: January 25, 2007, 07:09:10 AM »
Hey John,
    Yes, it is a USB. One thing to note, do not install the software, drivers that comes with the gamepad. You don't need those. Check out this thread.
« Reply #9 on: January 26, 2007, 01:11:51 PM »
Chaoticone,
I tried the settings you suggest, or at least, the part with the four axis. The axis work well, but I can only operate one at a time. Example: if i move the stick up a little, one axis starts to move. If I then move also a bit to the right, the only axes that moves is the previous one. To move the other axis, I first have to reach the center position. Is this to be expected? If not, is it about the other config screen? Because I couldn't really find out how to configure it like yours...
Sorry for all the troubles, and thanks!
