Hello Guest it is November 13, 2026, 09:51:27 AM
Author Topic: Multiple joy axis togheter  (Read 29204 times)
Re: Multiple joy axis togheter
« Reply #10 on: January 26, 2007, 07:00:08 PM »
Hi Franko,
   No problem. You should be able to move all axis at once. Try this, download the xml, screen set, and default grabber in the post listed below to your desktop. Rename something different from any xml, profiles, screen sets you already have and give it a play with your machine disabled. Watch your dros.
Have sent you another PM.
Offline JB
  •  15 15
« Reply #11 on: January 28, 2007, 12:03:07 AM »
Brett,
  How do you keep XP Pro from automatically installing drivers for USB hardware. I have uninstalled the driver for this joystick about 15 times going about it every different way I can think of, but then have to reboot to see if the joystick will work with MAch3. Then when I reboot the @#$%^@ driver reinstalls (it does this as it's booting up apparently).
Thanks for the help!
John
« Reply #12 on: January 28, 2007, 03:58:07 AM »
Chaoticone,
I'm really gratefull for all your time and efforts! I think we can solve this. But, in your last message, you mention a link to a thread that I cannot see. Am I missing something?
« Reply #13 on: January 28, 2007, 05:23:01 AM »
Hi Fellows,
    John, I would think you could click on start, right click on my computer, properties, hardware, device manager, find your joysick, right click on it, properties, driver, uninstall. Let some of the others confirm this before you try. You may want to do a restore point before you do anything.
Franco,
    Just click on this link.
http://www.machsupport.com/forum/index.php?topic=1391.0
« Reply #14 on: January 29, 2007, 02:32:20 PM »
Hey Franco,
    Here you go. These are the latest. I have remapped some keys in the screen set so be careful.
« Reply #15 on: February 03, 2007, 06:05:33 AM »
Thanks Chaoticone!
With your configuration files it works!
« Reply #16 on: February 03, 2007, 06:59:05 PM »
Your welcome Francopuk,
    Just remember, I have changed some hot keys in screen design so............................. be careful. Also, to make it do some of its tricks, you will actually be pushing three buttons at once.
