Hello Guest it is November 13, 2026, 05:01:44 PM
Author Topic: NEW: 'Official' PoKeys Mach3 Plugin - 'beta' version v0.01  (Read 62541 times)
Offline NeoTO
  •  504 504
    • PoLabs
Re: NEW: 'Official' PoKeys Mach3 Plugin - 'beta' version v0.01
« Reply #10 on: June 12, 2012, 12:45:06 PM »
We are already in contact with Brian on this issue. After we identify any bugs it will be a quick fix.
« Reply #11 on: June 21, 2012, 05:55:39 AM »
First, I'am so sorry for my bad english, but i do my best.
I have a pokeys56E my Problem:
I'am not able to Map an analog input (Poti on pin45) to the FeedOverride (DRO 821).
- NEW: Mach3 plugin: analog support (analog joystick, analog to DRO mapping, offsets and gains adjustment, automatic calibration)
How can i get it work?
Mach Version R3.043.062
Pokeys FW V3.0.30
Doesn't it work without Brains? Have anyone a Brain for me?
greez
Harry
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #12 on: June 21, 2012, 06:01:50 AM »
Hi, Harry
Although this plugin is in beta version, it still has some bugs. One of them was related to the analog to DRO mapping.
A new version of the plugin is expected to be released today together with a list of other minor and major fixes and improvements.
Matevž
« Reply #13 on: June 21, 2012, 06:25:15 AM »
Hi, Matevž
Today? That's fine! My weekend is rescued...  ;)
Okay, sounds good. I worked 5 Days on my machine without results.
I thought I am too stupid to configured Pokeys for my Mach3.
Harry
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #14 on: June 21, 2012, 11:08:55 AM »
Today we released an updated version of the plugin.
Updates/changes/fixes:
  - Mach3 MPG jogging done by PoKeys device
  - Mach3 plugin - Selectable polarity of the emergency STOP switch
  - Mach3 plugin - SetIODevOutput bug fixed
  - Mach3 plugin - limit switch handling bug fixed
  - Mach3 plugin analog inputs now can be reset to inactive, fixed bug with DRO mapping
  - Mach3 plugin - reconnect on lost connection
  - PoKeys55 PoExtBus glitches fixed
One of the most noticeable feature is definately MPG jogging - if enabled, PoKeys handles the axes movement instead of Mach3 engine. This results in way more fluid and responsive movement of the axes under MPG jog. PoKeys devices support only continuous MPG jog, which is the most useful in everyday work.
The plugin requires PoKeys 3.0.31 firmware, available here: http://www.poscope.com/productattachments/index/download?id=29
Mach3 plugin 'beta': http://www.poscope.com/productattachments/index/download?id=75
Manual: http://www.poscope.com/productattachments/index/download?id=77
For those who own PoKeys56E devices, take a look at our new support for Cosm web service (our test feed is available at http://cosm.com/feeds/62592). PoKeys56E devices can now be very easily configured to upload current sensor value to Cosm, where they can be access from all over the world.
Matevž, PoLabs
« Reply #15 on: June 21, 2012, 12:08:14 PM »
Hi, Matevz
Nice Job! it's amazing it works! Perfect!
The analoginput "to" DRO works very nice!
I have one Question:
Is there a Way to Map IO's to "User Buttons",
The Reason is my machine has much Buttons with VB - Scripts and this way maybe the easiest...
 regards
Harry
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #16 on: June 21, 2012, 12:16:41 PM »
You can map digital inputs directly to Mach3 OEM buttons (codes from 1 to 2000). What are the user buttons codes in your case?
« Reply #17 on: June 21, 2012, 01:08:24 PM »
Thanks for the fast Feedback,
In my case i use
pin1 to Jog On/Off it works
pin2 to "Activate a toolchange script button" called Button34, i have also testet 357 it doesn't works
pin3 to "Activate a Mach LED 170" it also doesn't work
Where is my mistake?
regards
Harry
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #18 on: June 21, 2012, 01:16:52 PM »
Hi, Harry
Please export your configuration and send it to matevz@poscope.com.
Matevž
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #19 on: August 11, 2012, 10:25:37 AM »
Today we released another updated version of the beta plugin.
 - Improved support for matrix keyboards
 - Connecting to PoKeys56E devices with static IP
 - Added support for Matrix LED for even more (up to 128) LED outputs
 - Stability updates in the firmware
The plugin requires PoKeys 3.0.36 firmware, available here: http://www.poscope.com/productattachments/index/download?id=29. The new PoKeys setup now also includes the latest version of the Mach3 plugin.
Matevž, PoLabs
