Hello Guest it is October 11, 2026, 02:28:19 AM
Author Topic: NEW: 'Official' PoKeys Mach3 Plugin - 'beta' version v0.01  (Read 61618 times)
Offline NeoTO
  •  504 504
    • PoLabs
The 'alpha' version (http://www.machsupport.com/forum/index.php/topic,21247.0.html) of the plugin got a major update:
  - NEW: PWM support
  - NEW: LCD support
  - NEW: analog inputs support (analog joystick, analog to DRO mapping, offsets and gains adjustment, automatic calibration)
  - NEW: IO mapping (Mach3 native input-output pins, additional 100 Mach3 IO device pins - device name PoKeys_{serial number})
  - NEW: dedicated menu for each device
  - NEW: homing support
  - NEW: support for pendant with the activation switch
  - NEW: Safety charge pump on pin 53
  - NEW: Fail-safe based on connection timeout
  + Various bug fixes of the alpha version
The plugin requires PoKeys 3.0.30 firmware, available here: http://www.poscope.com/productattachments/index/download?id=29
Mach3 plugin 'beta': http://www.poscope.com/productattachments/index/download?id=75
Manual: http://www.poscope.com/productattachments/index/download?id=77
Matevž, PoLabs
Offline borisz
  •  220 220
    • www.poscope.com
Re: NEW: 'Official' PoKeys Mach3 Plugin - 'beta' version v0.01
« Reply #1 on: May 31, 2012, 06:22:14 PM »
May 31, 2012
PoKeys 3.0.30 update available
We are releasing this update together with the new version of PoKeys Mach3 plugin.
SW+FW: http://www.poscope.com/productattachments/index/download?id=29
Mach3 plugin manual: http://www.poscope.com/productattachments/index/download?id=77
Changes:
  3.0.30 (30.5.2012)
  - AuxilaryBusSetDataBytes function - no arrays or pointers for better VBScript compatibility
  - Fast Encoder index reset bug fixed
  - Mach3 configuration delete option added
  - Mach3 plugin pulse engine settings bug fixed
  - NEW: Mach3 plugin: PWM support
  - NEW: Mach3 plugin: LCD support
  - NEW: Mach3 plugin: analog support (analog joystick, analog to DRO mapping, offsets and gains adjustment, automatic calibration)
  - NEW: Mach3 plugin: IO mapping (Mach3 native input-output pins, additional 100 Mach3 IO device pins - device name PoKeys_{serial number})
  - NEW: Mach3 plugin: dedicated menu for each device
  - NEW: Mach3 plugin: homing support
  - NEW: Mache plugin: support for pendant with the activation switch
  - NEW: Joystick HAT switch support added
  - Mach3 plugin Export configuration saving bug
  - Homing direction change saving fixed
  - Pulse engine bugs fixed (changing modes)
  - PoI2C module improved
« Reply #2 on: June 02, 2012, 04:13:40 PM »
Aftet update 3.0.30... PoNET kbd48CNC not work
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #3 on: June 02, 2012, 04:17:01 PM »
Please contact: support@poscope.com
« Reply #4 on: June 02, 2012, 08:07:33 PM »
working fine with
Development: Mach3 R3.043.062
« Last Edit: June 02, 2012, 08:09:06 PM by mach3 virgin »
« Reply #5 on: June 05, 2012, 11:17:28 AM »
I have a small problem with my 56E. I have it hooked up with a fresh Mach3 install , after setting  output 1 on pin one , i can send the pokeys pin high or low with the vb script activate signal(output1) command. But when I set the io to mach3 IO pin 1 from the config drop down , nothing happens. VB can detect the device with the GetIODevName command.  The GetIODev Input and Output commands seem to work , return true  , but nothing happens to the Pokeys 56E pin. Of coursed tried this with many pins , command combos. How do I 'activate the IO pins ?  ALSO. Great package, keep it up.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #6 on: June 05, 2012, 02:00:49 PM »
machiner, do you have the latest version of Mach3 (Mach3 R3.043.062) ?
Offline grc
  •  2 2
« Reply #7 on: June 10, 2012, 01:50:38 PM »
I have a POKEYS 55 board. I had it working on a pc in the house with Mach3 on it. I went to put it on the PC that is on the cnc machine yesterday and noticed there was a new plug in for mach3. I installed that and it is so easy now to configure compared to the old software except I cant get it to work. My Mach is version 3.042.040 not the latest but didn't want to updated in case I lost some settings, the firmware in the pokeys 55 has been updated to the latest which seems to be 2.1.21 and the software is 3.0.30. The board works if I just use the software but I must have done something wrong with the Mach3 plug in.
Geoff
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #8 on: June 10, 2012, 02:41:37 PM »
grc, please send me an email to matevz@poscope.com if you think it might be a bug.
« Reply #9 on: June 12, 2012, 09:34:11 AM »
Yes I do. I have tried different computers, fresh installs,and every trick I have learned in 20 years of cnc work.  Have license. also notice that the analog does not work either, I have ordered a second board , is there any REAL examples like a .set and vb script  that someone can say THIS WORKS.
