Hello Guest it is November 13, 2026, 05:01:30 PM
Author Topic: NEW: 'Official' PoKeys Mach3 Plugin - 'beta' version v0.01  (Read 62540 times)
Re: NEW: 'Official' PoKeys Mach3 Plugin - 'beta' version v0.01
« Reply #20 on: August 13, 2012, 05:45:59 AM »
Hi, I just gave the new version a try - everything seems to work great so far, there's just one thing that irritates me...
I have connected a 4x20 LCD to the primary pins, listed in the plugin's LCD-Screen as 23,24,25,26,   28,29,30.
I used these connectors and it seems to work ok.
But...
the plugin's "PoKeys Mapping" shows pin 23-29 (subsequently) including Pin 27 used for the LCD, while pin30 is marked as "not used"
It seems one can't change that manually.
So now I wonder what to do - leave Pin27 unused?
By the way, that's been the same in the previous version, no change with latest firmware/plugin version
Mike
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #21 on: August 13, 2012, 05:49:40 AM »
Hi, Mike
This bug unfortunately slipped through - please don't use either pins 27 or 30 for mapping. We will fix that in the next release.
Matevž, PoLabs
« Reply #22 on: August 13, 2012, 07:00:08 AM »
Hi Matevž,
thanks, I'll do that and wait for the next version.  :)
Mike
« Reply #23 on: November 19, 2012, 01:10:22 PM »
Hi Matevž,
Mike
Have you managed LCD to work?
On which pins?
I have the same problem here: http://www.machsupport.com/forum/index.php/topic,21247.msg161043.html#msg161043
« Reply #24 on: November 20, 2012, 06:53:31 AM »
Looking Good Matt,
Keep up the Good work!
Scott
