Hello
Guest
it is
November 13, 2026, 06:20:56 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
PoKeys
(Moderator:
NeoTO
Pokeys plugin install on K: ?
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Pokeys plugin install on K: ? (Read 72659 times)
msv
18
Re: Pokeys plugin install on K: ?
Reply #30 on:
April 10, 2012, 02:29:32 PM »
If i uncheck the MPG in ports and pins, i can not lit the mpg led on the mpg/jog flyout screen. I get no response att all from my encoder...
NeoTO
504
Reply #31 on:
April 10, 2012, 02:59:06 PM »
There was a small bug regarding the inputs for the encoder. Please install the plugin in the attachment.
To use the MPG in Mach3, enable the MPG in the Mach3 MPG/encoder settings. Leave pin A and B fields at 0.
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
msv
18
Reply #32 on:
April 10, 2012, 03:00:03 PM »
What DRO should i choose to set the encoder to MPG1?
NeoTO
504
Reply #33 on:
April 10, 2012, 03:02:07 PM »
Use the DRO 101.
www.poscope.com
msv
18
Reply #34 on:
April 10, 2012, 03:12:06 PM »
Thanks for the file, and your all the time fast response!
I have now installed the new pluginfile, enabled the MPG1, and entered zero:s in the ports and pins fields.
I use the DRO101, but i still get no response from the MPG. What am i doing wrong?
Carnoustie, Scotland
Reply #35 on:
April 10, 2012, 03:21:19 PM »
I have just tried and it works fine here.If you attach your Mach xml I can look at that to see if you have a Mach problem.
msv
18
Reply #36 on:
April 10, 2012, 03:37:43 PM »
Thanks!
Here are the files!
Reply #37 on:
April 10, 2012, 05:19:49 PM »
Well I am not sure what is wrong but I cant get your xml to work correctly with the MPG, I do get it to work a bit but its far from right. I will look further at it tomorrow and see if I can find the problem.
msv
18
Reply #38 on:
April 17, 2012, 02:45:17 PM »
Nothing new on this?
Reply #39 on:
April 19, 2012, 01:04:26 PM »
Sorry couldnt fnd anything and can only assume something is corrupt in the xml. May be worth making a new xml up and seeing if that helps but make sure you dont use the clone option or it will likely just pass the problem along.
Print
Pages:
1
2
3
4
Go Up
« previous
next »
