Hello Guest it is November 13, 2026, 05:54:20 PM
Author Topic: Pokeys plugin install on K: ?  (Read 72629 times)
Offline msv
  •  18 18
« on: April 08, 2012, 04:11:38 PM »
This is my first post on this forum, but i think not the last!
Im trying to install the Mach3 plugin for pokeys on my computer with no C: -drive. The hard-drive on this computer has the letter K: .
When i try to run the installation program downloaded from Polabs page, it will stop and tell me to select another drive than C:, but there is no selection for that....
Please help me!
/Micke
Re: Pokeys plugin install on K: ?
« Reply #1 on: April 08, 2012, 05:08:12 PM »
Just either type K instead of C or browse to where you want it to go.
Offline msv
  •  18 18
« Reply #2 on: April 08, 2012, 05:18:23 PM »
I cant find where to browse or type te location!
« Reply #3 on: April 08, 2012, 05:26:25 PM »
Assuming it is the same pokeys installer I have just looked at you do it from this part of the install. Either change the C to K or use the browse.
« Reply #4 on: April 08, 2012, 05:27:43 PM »
Wait a min, you said plugin, can you send a link to the one you are meaning?
Offline msv
  •  18 18
« Reply #5 on: April 09, 2012, 12:19:51 AM »
it is the plugin for mach3 on pokeys homepage: http://www.poscope.com/pokeys56u
i dont get the screen above when i try to run that installer!
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #6 on: April 09, 2012, 01:12:24 AM »
Please check these tread for the latest plugin: http://www.machsupport.com/forum/index.php/topic,21247.0.html
If you will still not be able to install it to K drive, please email us to: support (at) poscope.com
Offline msv
  •  18 18
« Reply #7 on: April 09, 2012, 09:39:08 AM »
Thanks, now i have installed it soccesfully on my computer.
But now to the next problem...
I have installed the pluginin, and configured a few buttons on my pendant. The problem is that when i for example press the Z-- button, the machine will not stop jogging when i release the button! It is configured as Button 312. The problem is similar to other buttons too. When i test the inputs in PoKeys configuration program, the buttons works just fine.
« Reply #8 on: April 09, 2012, 12:44:34 PM »
Try inverting the input setting.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #9 on: April 09, 2012, 01:14:33 PM »
@msv: I will contact Brian in regards to these 'push to jog' buttons in Mach3. Apparently, these need special handling in the plugin.
