Hello Guest it is November 13, 2026, 05:56:03 PM
Author Topic: Pokeys plugin install on K: ?  (Read 72630 times)
Offline msv
  •  18 18
Re: Pokeys plugin install on K: ?
« Reply #30 on: April 10, 2012, 02:29:32 PM »
If i uncheck the MPG in ports and pins, i can not lit the mpg led on the mpg/jog flyout screen. I get no response att all from my encoder...
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #31 on: April 10, 2012, 02:59:06 PM »
There was a small bug regarding the inputs for the encoder. Please install the plugin in the attachment.
To use the MPG in Mach3, enable the MPG in the Mach3 MPG/encoder settings. Leave pin A and B fields at 0.
Offline msv
  •  18 18
« Reply #32 on: April 10, 2012, 03:00:03 PM »
What DRO should i choose to set the encoder to MPG1?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #33 on: April 10, 2012, 03:02:07 PM »
Use the DRO 101.
Offline msv
  •  18 18
« Reply #34 on: April 10, 2012, 03:12:06 PM »
Thanks for the file, and your all the time fast response!
I have now installed the new pluginfile, enabled the MPG1, and entered zero:s in the ports and pins fields.
I use the DRO101, but i still get no response from the MPG. What am i doing wrong?
« Reply #35 on: April 10, 2012, 03:21:19 PM »
I have just tried and it works fine here.If you attach your Mach xml I can look at that to see if you have a Mach problem.
Offline msv
  •  18 18
« Reply #36 on: April 10, 2012, 03:37:43 PM »
Thanks!
Here are the files!
« Reply #37 on: April 10, 2012, 05:19:49 PM »
Well I am not sure what is wrong but I cant get your xml to work correctly with the MPG, I do get it to work a bit but its far from right. I will look further at it tomorrow and see if I can find the problem.
Offline msv
  •  18 18
« Reply #38 on: April 17, 2012, 02:45:17 PM »
Nothing new on this?
« Reply #39 on: April 19, 2012, 01:04:26 PM »
Sorry couldnt fnd anything and can only assume something is corrupt in the xml. May be worth making a new xml up and seeing if that helps but make sure you dont use the clone option or it will likely just pass the problem along.
