Hello Guest it is November 13, 2026, 05:01:15 PM
Author Topic: NEW: 'Official' PoKeys Mach3 Plugin - 'alpha' version v0.01  (Read 131504 times)
Re: NEW: 'Official' PoKeys Mach3 Plugin - 'alpha' version v0.01
« Reply #40 on: April 14, 2012, 04:58:46 AM »
I have just tried with the USB version and it is working as it should :)
« Reply #41 on: April 20, 2012, 08:49:33 AM »
I have also a problem with the index, encoder with Pokey 56E.
When i  "Enable the encoder", the counter seems to count ok.
But when i aslo activate "Enable reset on index" the count value is not correct, is not counting enough.
When i put the pokey input to ground, then the count value is reset.
I am reading the RAW values from the pokey config program. (so at the moment without Mach3)
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #42 on: April 20, 2012, 08:54:14 AM »
This one is in the 'investigation' already.
Offline LWW
  •  1 1
« Reply #43 on: April 24, 2012, 03:00:58 AM »
The old plug-in not used? How now it is possible to show DRO-1000 on the screen?
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #44 on: April 24, 2012, 03:41:45 AM »
What are you referring to? Give more details on what you would like to know.
« Reply #45 on: November 19, 2012, 12:36:06 PM »
I made a pendant:
using Pokeys. On old plugin i have drive LCD with macropump.
I saw that you have made new plugin, so i decide to upgrade Pokeys FW,
 and install new mach3 plugin. Than i encounter problems with writing to LCD.
I have set lcd plugin to secondary pins (28-34) because of previous pendant setup.
Now the buttons and MPG are working, but i dont get any content to LCD.
I have setup plugin like that:
« Last Edit: November 19, 2012, 12:44:32 PM by germil »
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #46 on: November 20, 2012, 12:45:17 AM »
Hi, Milan
We are working on supporting the LCD on PoKeys55. PoKeys56 series use a new buffered LCD mode, which is used in Mach3 plugin to improve speed.
Matevž
« Reply #47 on: November 20, 2012, 03:02:03 AM »
Thank you Matevž.
Best regards,
Milan
