Hello Guest it is November 13, 2026, 05:01:22 PM
Author Topic: NEW: 'Official' PoKeys Mach3 Plugin - 'alpha' version v0.01  (Read 131505 times)
Re: NEW: 'Official' PoKeys Mach3 Plugin - 'alpha' version v0.01
« Reply #30 on: April 08, 2012, 10:59:40 AM »
ok thanks.
Offline txpto
  •  26 26
« Reply #31 on: April 08, 2012, 06:13:40 PM »
oh my god !!!!
today is special day for me !!!
Offline txpto
  •  26 26
« Reply #32 on: April 08, 2012, 06:32:17 PM »
NeoTO just bought a new pokeys usb board to Spain.
Is for make a 3 axys control with a Mach3 software STEP/DIR
STEP/DIR of pokeys I converted to quadrature encoder A and B channel for make a "gearing" with a electronic inverter.
When receive pokeys and test all, I will write here my experience.
Thanks fot all.
Carlos
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #33 on: April 09, 2012, 10:04:05 AM »
@Hood: apparently, index signal uses 'normal' polarity - 1 should indicate a index signal and 0 no signal. I will add an additional option to invert the polarity.
« Reply #34 on: April 09, 2012, 12:17:33 PM »
I am not really sure I follow but will wait to see what happens with the update :)
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #35 on: April 09, 2012, 01:52:04 PM »
This option was made for an encoder that outputs 1 when the index signal is present and 0 when it is not. This is the other way around from what you have when you connect index input pin to ground at the moment of the index signal.
« Reply #36 on: April 09, 2012, 02:03:21 PM »
Yes but I have also tried connecting to 3.3v  and it acts the same.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #37 on: April 10, 2012, 03:00:32 PM »
I've tested it and it should behave like this:
- on index pin rising or falling signal front, the counter is reset. It should not keep resetting.
« Reply #38 on: April 10, 2012, 03:08:48 PM »
I can not get it to work here. If I apply 5v to pin 9 nothing happens, if I remove 5v from Pin 9 nothing happens. I can get it to zero if I connect to Gnd but it will not count even if I remove the Gnd connection after.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #39 on: April 14, 2012, 03:02:43 AM »
Hood, do you have one PoKeys board or is it possible that you try this on another one? Enable index inputs and turn the MPG - it must count. If you then connect the input to GND, the counter must reset. Even if you keep it at GND, the counter must then count from 0 and not reset.
Namely, we can not replicate your situation here.
