Hello Guest it is September 22, 2026, 11:38:03 AM
Author Topic: Eagle KM-750..Anilam Crusader GX-M  (Read 207479 times)
Offline ardor
  •  130 130
Re: Eagle KM-750..Anilam Crusader GX-M
« Reply #100 on: April 15, 2007, 03:07:29 AM »
Whilst working on the ACAD for the wiring I finally think I know something.
Being your basic gearhead +12v on the battery is hot, -12v is ground.  So when I see -12v, GND, and SHEILD, it all means connect to da frame.
Now I am beginning to see that's WRONG.
Back to the spagetti bowl
Someone hurry and tell me if I'm still fecked up, before I get this all rewired.
Ashby
There is no approved dental use for WD40
Offline fdos
  •  326 326
« Reply #101 on: April 15, 2007, 06:11:31 AM »
-12v is the negative rail on a dual rail supply.  Not 0v or GND ;)
A dual rail 12v supply will normally have -12v  0v   12v
Wayne...
« Reply #102 on: April 15, 2007, 09:37:57 AM »
Here is the battery equivilent. It should show you why your power supply would not like the way you had it wired.
Darek
Offline ardor
  •  130 130
« Reply #103 on: April 15, 2007, 01:20:56 PM »
OK guys
Hope to have the wiring dwg done soon.
Soon = Mon or Tue.
Ashby
Back in the day, (1958) I put a 413 with a 12v starter in an old Plymouth with a 6v system.  Put a 12v battery in it and tapped the 3rd cell for 6v to run the junk in the car.
Whoa...a dual rail 6v.
Batteries didn't last long but it was the hottest thing on Woodward Ave.
Edit: If I look at that vista thing much longer I'm going to go batty............ or battier.  Put the tin foil hat on but that won't turn it off.
« Last Edit: April 15, 2007, 01:57:47 PM by ardor »
Offline ardor
  •  130 130
« Reply #104 on: April 15, 2007, 08:38:54 PM »
Here's what it looks like now.
« Last Edit: April 16, 2007, 01:05:52 AM by ardor »
Offline ardor
  •  130 130
« Reply #105 on: April 18, 2007, 03:45:37 AM »
Hope REV 1 is easier on the eyes
Offline ardor
  •  130 130
« Reply #106 on: April 20, 2007, 05:20:28 PM »
Thot you might just want to know who you are dealing with.
« Reply #107 on: April 20, 2007, 07:44:03 PM »
 ;D
Ardor,
You are a mess.
Offline ardor
  •  130 130
« Reply #108 on: April 22, 2007, 02:48:07 AM »
I have connected power to X axis only.  Using the Pixie diagnostics I can move the axis.  I can't move it with Mach 3.
Here's my xml file.
Ashby
« Reply #109 on: April 22, 2007, 01:57:34 PM »
Ashby
 If you are just not getting a movement in Mach when trying to Jog with the keyboard then it is probably because you dont have the Jog Control enabled.
