Hello Guest it is November 07, 2026, 12:15:11 PM
Author Topic: Eagle KM-750..Anilam Crusader GX-M  (Read 211465 times)
Re: Eagle KM-750..Anilam Crusader GX-M
« Reply #80 on: April 03, 2007, 06:39:04 AM »
Yes it is a f1. If you had a shielded wire coming from the second 502 D/A board your speed was probable handled completely in the CNC.
Do your tools have a retension knob or threaded for a draw bar?
Darek
Offline ardor
  •  130 130
« Reply #81 on: April 03, 2007, 02:08:53 PM »
Retention knob.
That PDF that I posted for the PLC is a programming manual, no wiring details.  ........Rats.
The OUT. SVO-ON supplies ground directly to the relay of which the other side is connected to +24v (no PLC invovled.).
Where does the 24v come from.  The only 24v I see is from the power supply I took from the card cage.  24v on that isn't connected to anything yet.
Ashby
« Last Edit: April 03, 2007, 02:14:01 PM by ardor »
There is no approved dental use for WD40
« Reply #82 on: April 03, 2007, 05:26:50 PM »
There is a 24V power supply right above your PCB 801 board ( The one with 3 icecube relays.)
My tools are threaded for a draw bar with a Kurt actuator ( 3/8" CP air hammer.).
Darek
Offline ardor
  •  130 130
« Reply #83 on: April 03, 2007, 05:38:44 PM »
That's what I get for posting info from what we laughingly call my memory.  The machine is only 50 ft. from the office.  Too lazy to go look. ::)
Ashby
So now I'm ready to whack a ribbon cable and connect an enable (1) from a pixie.  From the drawing, the odd numbers on the connector are on one row and the even on the other?
« Last Edit: April 03, 2007, 05:42:19 PM by ardor »
« Reply #84 on: April 03, 2007, 06:47:36 PM »
Here is the diagram for mine. I would imagine the CNC to PLC interface would be the same for both machines.
The rest of the diagram will be like using a map of Alabama get around in Georgia!
Darek
Offline ardor
  •  130 130
« Reply #85 on: April 03, 2007, 08:05:27 PM »
How disturbing it is to me to have to display the level of my ignorance. >:(  That sheet IS in my wiring diagrams.
Sending you a PM
Ashby
« Reply #86 on: April 03, 2007, 08:48:38 PM »
Actually that is a good thing!
As far as ignorance, I would not be much help if you had a machining question.
Darek
Offline ardor
  •  130 130
« Reply #87 on: April 07, 2007, 06:51:25 PM »
Now I'm trying to figure out my limit switches.  I have 3 per axis, all Normally Closed . On the X........ X+ & X-(24V), overtravel (servo disconnect)  My Accu-Step BO board has one lug for each axis,  Labeled "LS".  I have read the section in the Mach 3 users guide on limit switches and the documentation that comes with the BO board.  Can't see that I can use 3 per axis with what I have.  Still have to turn on coolant after I (we) get this down.
I have another printer port.  If I need another BO board I'd appreciate a recomedaton or two.  Doesn't seem that I would need anything as fancy as what I have.
Ashby
EDIT:  Could I use the XYZ minus switches as Home?
         Not disconnect, run a jumper from NC contact on switch to LS lug on BO board?
         Don't forget >>> I'm easily confused.
P.S.  Merry Christmas
       Happy New Year
       Have a nice Easter.!!
« Last Edit: April 08, 2007, 08:30:40 PM by ardor »
Offline ardor
  •  130 130
« Reply #88 on: April 09, 2007, 04:13:41 AM »
Darek
I tried NC contact to BO board as above.  No joy.
The BO board wants to see a connection to ground broken by the limit sw.  The 24v negative from the power supply isn't connected to chassis ground.
So if I connect limit sw NC to BO board AND power supply 24v negative will that work ??
Or will that mess up PC board 803 ?
Ashby
« Last Edit: April 09, 2007, 04:17:58 AM by ardor »
« Reply #89 on: April 09, 2007, 05:31:13 AM »
This is how mine are setup. If yours are the same, I would leave the middle switches as is ( This is the loop that kills the servos.).
The RED (X+), GRAY (X-), ORN (Y+) and YEL (Y-) will be the inputs to the board. The BRN wire that supplies +24v to the switches will have to be switched to ground now.
Darek
« Last Edit: April 09, 2007, 05:41:29 AM by HillBilly »
