Hello Guest it is November 13, 2026, 12:14:27 PM
Author Topic: 4th axis strange development/ jerky movements  (Read 13835 times)
« on: March 03, 2012, 04:08:41 PM »
Machine has been and running great with 4th axis. Turned it on today and I get incremental movement on the a (4th) axis. I give it a a command and the rotary head doesn't have a fluid movement to that position, just a jerky move a couple of degrees, dead stop, repeat until A position reached. Even in G1. I don't remember changing any parameters.
Any Help?
i_r_
Re: 4th axis strange development/ jerky movements
« Reply #1 on: March 03, 2012, 04:27:51 PM »
If you attach your xml I will look see if there is a problem with it. Do the DROs show the jerky movement?
« Reply #2 on: March 03, 2012, 04:38:59 PM »
Yes,
The control seems to be sending out pulses of movements. I can manually move the a axis and it is as smooth as butter. This just started. Do I just search for a .xml file?
thanks
Kerry
« Reply #3 on: March 03, 2012, 04:40:34 PM »
Open Mach and look lower right for the name of the profile you are using then look in the mach folder for a file of that name with an xml extension.
« Reply #4 on: March 03, 2012, 04:52:01 PM »
Lets see if this works.
« Reply #5 on: March 03, 2012, 04:57:24 PM »
Try setting your kernel to 25KHz and restart Mach and see if that helps.
« Reply #6 on: March 05, 2012, 08:03:15 AM »
Thanks Hood!
That did it.
have fun
i_r_
