Hello Guest it is November 13, 2026, 11:28:16 AM
Author Topic: Pause between g-code steps  (Read 20567 times)
« on: February 07, 2012, 02:11:01 PM »
New here.. looking for help with a Mach3 issue. Sorry if this is the wrong place to start this thread.
When running a program, there is a short pause between g-code moves.
I have checked that it's set to Constant Velocity not Exact Stop. Any other ideas on how to fix this?
Could very well be my g-code is poorly written and it's not a Mach3 problem at all...
cbade
Re: Pause between g-code steps
« Reply #1 on: February 07, 2012, 03:42:17 PM »
Does your G Code have a G61 in it?
« Reply #2 on: February 07, 2012, 03:47:39 PM »
It does not. I also checked in the settings to be sure the Constant Velocity is checked. I can add a G64 and try the code again.
« Reply #3 on: February 07, 2012, 03:49:06 PM »
If you attach your code and your xml maybe the issue can be found.
« Reply #4 on: February 07, 2012, 03:55:58 PM »
I've attached the .XML used and the G-code in question. The pause happens between each move.
Thanks for your help.
« Reply #5 on: February 07, 2012, 04:11:33 PM »
Look on Settings page and disable CV Feedrate and see if that helps.
« Reply #6 on: February 07, 2012, 04:32:39 PM »
Looks like that did the trick. The setting was at +1.000 and I disabled it.
I'm curious as to why this is the fix.. I'll do some google searching.
Thanks a ton! You're the man, Hood.
« Reply #7 on: February 07, 2012, 04:37:07 PM »
I would say what that means is you were telling the machine to slow to 1 unit per min before doing the CV.
« Reply #8 on: February 07, 2012, 04:40:30 PM »
So another fix could be to change the CV Feed-rate value to the same as the feed-rate set by the G-code? I'll try it.
« Reply #9 on: February 07, 2012, 04:45:36 PM »
Yes that should work but usually its just disabled by default I think. I imagine it is meant for people who have machines that are not very rigid but with fast acceleration, could be wrong though :)
