Mach Discussion => General Mach Discussion => Topic started by: cbade on February 07, 2012, 03:11:01 PM
New here.. looking for help with a Mach3 issue. Sorry if this is the wrong place to start this thread.
When running a program, there is a short pause between g-code moves.
I have checked that it's set to Constant Velocity not Exact Stop. Any other ideas on how to fix this?
Could very well be my g-code is poorly written and it's not a Mach3 problem at all...
cbade
Does your G Code have a G61 in it?
It does not. I also checked in the settings to be sure the Constant Velocity is checked. I can add a G64 and try the code again.
If you attach your code and your xml maybe the issue can be found.
I've attached the .XML used and the G-code in question. The pause happens between each move.
Thanks for your help.
Look on Settings page and disable CV Feedrate and see if that helps.
Looks like that did the trick. The setting was at +1.000 and I disabled it.
I'm curious as to why this is the fix.. I'll do some google searching.
Thanks a ton! You're the man, Hood.
I would say what that means is you were telling the machine to slow to 1 unit per min before doing the CV.
So another fix could be to change the CV Feed-rate value to the same as the feed-rate set by the G-code? I'll try it.
Yes that should work but usually its just disabled by default I think. I imagine it is meant for people who have machines that are not very rigid but with fast acceleration, could be wrong though :)
Found this via another forum:
http://www.machsupport.com/docs/Mach3_CVSettings_v2.pdf
It recommends enabling CV and disabling all CV settings until more familiar with the system and its interactions.
Thanks again for your help in solving this issue.
No probs :)
I would take that doc with a pinch of salt. As I've said in many threads - it's not very good and in some places just plain wrong.
Your original CV Distance of 1.0 means you're allowing (not telling) CV to drop to 1 unit/min if it needs to which is (as you've found on your machine) just about the same as exact stop. Setting this to your commanded feedrate is pointless - CV can't do that by it's very nature.
Ian
