Hello Guest it is November 18, 2026, 10:43:30 AM
Author Topic: Pause between g-code steps  (Read 20626 times)
Re: Pause between g-code steps
« Reply #10 on: February 07, 2012, 04:48:52 PM »
Found this via another forum:
http://www.machsupport.com/docs/Mach3_CVSettings_v2.pdf
It recommends enabling CV and disabling all CV settings until more familiar with the system and its interactions.
Thanks again for your help in solving this issue.
« Reply #11 on: February 07, 2012, 04:49:57 PM »
No probs :)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #12 on: February 08, 2012, 06:48:43 AM »
I would take that doc with a pinch of salt. As I've said in many threads - it's not very good and in some places just plain wrong.
Your original CV Distance of 1.0 means you're allowing (not telling) CV to drop to 1 unit/min if it needs to which is (as you've found on your machine) just about the same as exact stop. Setting this to your commanded feedrate is pointless - CV can't do that by it's very nature.
Ian
