Hello Guest it is November 11, 2026, 03:02:14 PM
Author Topic: Ethernet SmoothStepper first test  (Read 264249 times)
Offline rcaffin
  •  1,073 1,073
Re: Ethernet SmoothStepper first test
« Reply #90 on: February 12, 2012, 01:01:56 AM »
rcaffin can you show where you increased that buffer by a screen print i can't seem to find it..
i am using version 10da2 of the ess pluggin..thanks
Its under Plugin Control, something to do with ESS config, bottom left hand corner of screen.
Can't fire up actual CNC right now - big storm, brown-out on some phases of grid ... Running this machine on special mains.
I'll look later.
« Reply #91 on: February 14, 2012, 03:52:20 PM »
Again Referencing:
Tested with Mach R3.043.058 and ESS plugin ESS_v10da2.
Commands DoOEMButton(22) (23) and (24) are working fine.
Command RefCombination(x) is not working correct.
It is working with single axis (1,2,4,8...) argument but not with combination of them.
For example: RefCombination(3) moves only x axis,
RefCombination(6) moves only y axis.
Is this bug in ESS plugin?
Andreas.
Offline rcaffin
  •  1,073 1,073
« Reply #92 on: February 14, 2012, 08:18:58 PM »
Hi mach3user
See attached. BLHC, with '2000' in it. It came with 1024 in it I think.
Roger
« Reply #93 on: February 15, 2012, 07:33:00 AM »
thanks rcaffin will look into it on my system just waiting for better weather kinda cold in the garage but I am changing out the older USB smoothstepper with the Ethernet one since I have had intermittent stops due to noise that no matter what I tried it would not go away and the newer version is suppose to be more noise resistant(that and I have a c25 breakout board too)....
I think the plugin for the ess Needs a little more evolving but it's looks close enough for me so far..
Offline rcaffin
  •  1,073 1,073
« Reply #94 on: February 15, 2012, 02:30:05 PM »
Same experience. Now immune to noise.
Roger
« Reply #95 on: February 21, 2012, 10:57:02 PM »
I got mach3 connected to the smoothstepper ethernet and it moves my Sieg KX3 axis fine but it does not turn on the spindle. Is there any settings I need to set for this?
Offline rcaffin
  •  1,073 1,073
« Reply #96 on: February 21, 2012, 11:00:27 PM »
I suspect that you don't have Mach set up with the right pin for whatever physical connection you have to the spindle. Detailed checking ...
« Reply #97 on: February 21, 2012, 11:21:29 PM »
Using the KX3 profile and it works fine on my desktop computer with a parallel port. Same setting for the pin no?
Offline rcaffin
  •  1,073 1,073
« Reply #98 on: February 21, 2012, 11:30:16 PM »
Actually, maybe not. I know Greg did make a few changes when he extended Port 3. Check at Warp9 web site.
« Reply #99 on: February 22, 2012, 04:53:34 AM »
Hmm right now its set in ports and pins config as
steppin# 14
dirpin # 16
Dir low active enabled
step low active enabled
step and dir port 1
Should I maybe play around with this setting?
