Hello Guest it is November 11, 2026, 03:02:18 PM
Author Topic: Ethernet SmoothStepper first test  (Read 264249 times)
Offline thosj
  •  542 542
Re: Ethernet SmoothStepper first test
« Reply #30 on: November 25, 2011, 05:34:33 PM »
I left my ESS inside my computer box where the USB SS lived. No problem finding 5v in there!!
Tom
« Reply #31 on: November 27, 2011, 03:08:38 PM »
I'm redesigning the back panel of my shortly to be released "ready to run" enclosure. The current configuration for the USS (USB SmoothStepper) uses a USB panel mount extension lead.
The new design will have the ESS and USS mount againt the back panel so that the LED indicators are accessible and visible. I will hopefully have that done this week.
Attached is an image of the current back panel.
I'm also designing a stand-alone enclosure for the ESS to provide any easy way of upgrading from a parallel
 to Smooth Stepper without having to modify existing Controller  enclosures.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #32 on: December 06, 2011, 07:59:52 AM »
Well I still have not been able to get the ESS to fail, time to devise more evil testing procedures  >:D
I did get the new SSENC-2 finished up though. I have been building the USB version (SSENC-1) for more than a year now. Since the new ESS and the USB version share the same footprint only the back panel had to be modified. I've been toying with the idea of making a 2" longer enclosure available. The end panels would the same the increased depth would provide room for adding a few operator controls like using out EZ-MPG1 for SRO and/or DRO controls.
Happy machining , Jeff Birt
« Reply #33 on: December 07, 2011, 02:39:25 AM »
Any news of when it will be for sale?
« Reply #34 on: December 07, 2011, 06:31:16 AM »
Greg was hoping later this month, he is currently making a test bed for checking them so hopefully it will be soon as I want a few more especially if I manage to make the differential and 24v I/O bobs  ;D
« Reply #35 on: December 07, 2011, 08:20:08 AM »
Does the SS support SwapAxis(). I was leanining toward the KFlop for my new router, but it looks like the new SS and a PMDX-126 might be the way to go.
« Reply #36 on: December 07, 2011, 09:37:44 AM »
Yes, or at least the SS does and I would imagine the ESS would but if you give me 5 mins I will test it out for you.
« Reply #37 on: December 07, 2011, 09:43:27 AM »
Yes it definitely does :)
« Reply #38 on: January 19, 2012, 04:39:21 AM »
I jumped on here to ask about ESS swapaxis, so I have that answer, thanks!
Does anyone know if the ESS can co-exist with TCP modbus?   (I will take time later to read this entire thread, but for now I would much appreciate an answer to this if anyone knows).
« Reply #39 on: January 19, 2012, 05:13:08 AM »
Afraid my PLCs are via serial so cant say for sure if it would be ok but I can say I have an Ethernet PoKeys and I have used that with the Ethernet SS whilst testing the PoKeys encoder inputs and it was fine.
